Go Back   Automotive Forums .com Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 12-29-2004, 05:47 PM   #1
mongooze
loose shifting
my shifter is wobbly when it is engaged in most of my gears its tight in 2nd and 5th but 1, 3, and 4 its really loose. any ideas on what it could be
mongooze is offline   Reply With Quote
Old 12-29-2004, 05:59 PM   #2
DeleriousZ
DeleriousZ's Avatar
Send a message via MSN to DeleriousZ
Re: loose shifting
the bushings on the shift knob most likely... probably need to be replaced..
http://www.ttzd.com/tech/bushingstech.html
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
DeleriousZ is offline   Reply With Quote
Old 12-30-2004, 12:33 AM   #3
freakonaleash1187
freakonaleash1187's Avatar
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: loose shifting
it is the shifter bushings, the bottom bolts are a bi**h to get to. i would buy the bronze shifter bushings from splparts.com instead of the oem rubber ones.
-Jared
ZedEx Crew Member #2
freakonaleash1187 is offline   Reply With Quote
Old 12-30-2004, 12:37 AM   #4
sivic02
sivic02's Avatar
Re: loose shifting
I swapped some shifer bushings in my car after about 20k and even then i felt a dramatic difference in the way it shifts especially under hard shifting. Another great thing about them is you shoukd be able to find some for about 15 bucks
Here's to being single, seeing double, and sleeping triple
sivic02 is offline   Reply With Quote
