Go Back   Automotive Forums .com Car Chat > Chevrolet > Impala | Impala SS
Old 09-30-2020, 07:28 PM   #1
MarkWilliams64
2014 Impala Limited P0496 & P0442
2014 Impala Limited 133,000 Miles
Check Engine Light on.
When I scan it I get P0496 & P0442.
When it originally happened I only had P0442, I thought I had a bad Gas Cap so I replaced it and the code continued, and now I have P0496.
If I clear the codes, the come back when the Gas Thank gets low ~ 1/4 of a tank.
The last two times I have filled up the car started rough at the gas station when I went to leave.
But after that initial first time start after fill up there are no starting issues at all.
I have a EVAP Purge Valve coming from Rock Auto, as a Mechanic friend recommended I replace that.
Just want to make sure I'm on the right track.
MarkWilliams64 is offline   Reply With Quote
Old 09-30-2020, 08:06 PM   #2
maxwedge
A990 racer
Re: 2014 Impala Limited P0496 & P0442
May be if all the connections and lines are good.
maxwedge is offline   Reply With Quote
Old 10-01-2020, 08:06 PM   #3
MarkWilliams64
The part came today and I watched a YouTube Video, which showed if the part on the car had constant suction.
It did.
I replaced it and the new one did not have suction.
So I think it may be fixed.
