Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 06-07-2010, 04:41 PM   #1
jcase350
Idle Surge
I have a 90 camaro Iroc w/ 350. The idle is surging up and down pretty bad and it likes to die. Doesn't do it all the time, sometimes it runs fine. Even at higher RPMs you can tell it's still surging a little. I just got done replacing the EGR Valve, Cap and rotor, TPS Sensor, plug wires, plugs, fuel filter, and the ignition coil. What else could it be?? Thanks
1990 Iroc-z 350 TPI
jcase350 is offline   Reply With Quote
Old 06-08-2010, 07:41 AM   #2
wrightz28
is bring'n sexy back
wrightz28's Avatar
Re: Idle Surge
Idle speed control motor is probably gunked up.
wrightz28 is offline   Reply With Quote
Old 06-13-2010, 10:25 AM   #3
jcase350
Re: Idle Surge
I checked the IAC Motor and it looked clean. Someone had suggested to replace the coolant sensor. It was only 20 bucks so i went ahead and replaced it. Seems to be running ok for now. I'll keep driving it over the next couple of days to see if it really fixed it. If it doesn't...any other ideas?? Also, does anyone make a programmer for the 90 camaro to adjust computer settings?
1990 Iroc-z 350 TPI
Old 06-13-2010, 12:44 PM   #4
jcase350
Re: Idle Surge
Also, I just checked to voltage on the TPS sensor and it's reading .75 volts with the ignition on without it running. Is that to high or should it be set right at .54 volts??
1990 Iroc-z 350 TPI
Old 06-14-2010, 11:40 AM   #5
jcase350
Re: Idle Surge
Alright guys...turns out the Coolant temperatur sensor didn't work...still doing the same thing. I noticed that it only does it when it is extremely hot outside or the car has come up to temp. Any ideas? Could it be the TPS not adjusted properly. Also, the is a ticking coming from under the hood. The ticking gets faster as you rev the engine. HELP!!
1990 Iroc-z 350 TPI
Old 06-14-2010, 07:31 PM   #6
MattLast24
Re: Idle Surge
Hmmm, sounds like an over heating problem to me. Check coolant, radiator, sensors, and as well hoses and wiring. is it TPI or carb?
MattLast24 is offline   Reply With Quote
Old 06-14-2010, 07:40 PM   #7
jcase350
Re: Idle Surge
It is TPI. It runs about 170 give or take. It might get up to 200 but thats about it. Coolant, Radiator and hoses all good.
1990 Iroc-z 350 TPI
Old 06-14-2010, 08:19 PM   #8
MattLast24
Talking Re: Idle Surge
Hmm quiet stumped with this one. I have a 1986 with a 305 but its carbed. One thing is might be is cat converter. If its cloged not much will flow through there and in term with have backed up exhaust and in that case die. It did it to me a few times. check the cat converter. Let me know what goes down and I'll help ya most I can.
Old 06-14-2010, 08:30 PM   #9
jcase350
Re: Idle Surge
Thanks for the idea but no cat on the car...I had it removed a while back just for that reason. Thanks though!!
1990 Iroc-z 350 TPI
Old 06-14-2010, 08:34 PM   #10
MattLast24
Re: Idle Surge
haha well then. Hmm... I want to say something clogged but as far as that goes it's hard to figure out now.. nothing as far as you know has gotten into the engine right? like dirt, no old oil, metal shavings?
Old 06-14-2010, 08:37 PM   #11
jcase350
Re: Idle Surge
Nothing that I can think of. Is the TPS adjustable? Do you know if there is a way to test the IAC motor to see if it's bad?
1990 Iroc-z 350 TPI
Old 06-14-2010, 08:49 PM   #12
MattLast24
Re: Idle Surge
It should be, not to big on TPS but if I'm correct yes. As far as IAC motor you can clean it with a cleaner on a swab but to tell if its bad would be to look at it and see if theres any excessive wear or marks, as well as gunk.
Old 06-14-2010, 08:51 PM   #13
jcase350
Re: Idle Surge
Thanks Matt...I'll do some more work on it tomorrow...let you guys know what happens. Thanks for the help!!
1990 Iroc-z 350 TPI
Old 06-14-2010, 08:57 PM   #14
MattLast24
Re: Idle Surge
No problem, oh while your on here I was wondering if you would now some good mods for a 305? I got headers, new air breather and exhaust. and other ideas on what would help with performance?
Old 06-14-2010, 09:05 PM   #15
jcase350
Re: Idle Surge
I've got all MSD ignition parts on mine, ignition coil, distributor cap, rotor, and wires. All those are pretty cheap. Not sure if you have messed with your timing, but you can advance your timing. I also have a performance chip installed in the computer. Don't know if you have a SMOG pump or not....I took mine off. Not sure if that really helps with performance or not. I don't know how far you want to go...I rebuilt my 350 bored 30 over, oversized pistons, and a bigger cam. Hope that helps.
1990 Iroc-z 350 TPI
