| Latest | 0 Rplys |
12-02-2005, 08:20 AM | #1 | |
gas pedal sticking
Three times now I have been driving my 2004 TB and the gas pedal has stayed in place when I remove my foot to slow down. The first 2 times I tapped it a little with my foot and it "unstuck" and the car drove normally. The 3rd time, the tapping made it worse and I accelerated rapidly towards a school bus, with my own kids in the car. I applied the brake but the car was fighting it. I finally panicked and shut the car off. It was really scary and I don't trust the car now. Has anyone heard of this problem? Thanks.
12-02-2005, 10:18 AM | #2 | |
Re: gas pedal sticking
Get it to a dealer immediately!
Are you sure it's the pedal staying down? Or just that the RPMs don't back off when you release pressure on the pedal? The former would indicate mechanical sticktion in the accellerator pedal linkage; the latter might be a fault in the switch/sensor/pot that senses the pedal position and tells the computer. Either way, you need to get it fixed. Now. Good luck. . |
12-02-2005, 11:32 AM | #3 | |
I know stuff
That system is a "fly by wire" design. There is no physical linkage that links the pedal assembly to the throttle.
If the throttle is sticking, it could be the return spring for pedal assembly. Either way, get it to the dealer
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
12-05-2005, 12:26 PM | #4 | ||
I have no idea if I'm "replying" correctly, but thanks for the advice. I got it to the dealer right away. They said Chevy has never heard of this problem. They updated some software and reset everything and gave it back to me. I am driving it again, but I'm constantly on guard in case it happens! I guess putting it into neutral and pulling over is the right response? Thanks again. |
12-05-2005, 02:03 PM | #5 | ||
Re: Re: gas pedal sticking
If it was me, I'd turn off the ignition. The downside here is that if you panic and turn the key too far, you'll lock the steering. That'd be less than optimum. In any event, you'd lose the power assist for steering, too. Not a problem if you're prepared for it. So, I suppose, you are better off blowing the engine than having no steering and colliding with someone else. Again, perhaps the computer is smart enough to save the engine. Seems to be able to do everything else imaginable. If the "stuck throttle" thing happens again, it should go right back to the dealer. At least that way, if you do have a collision or a blown engine, you've got multiple receipts proving that you tried to get it fixed. (Any chance the floormats are interfering with the throttle return???)
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
12-05-2005, 07:00 PM | #6 | ||
Re: Re: Re: gas pedal sticking
OK, so do I blow the engine or crash into something? Maybe I should check with the dealer to see what action I should take. I had no idea my car was "drive by wire". It's not like it's an Airbus or anything. I am careful to put it in park when I'm at a red light. And no, the floormat wasn't the issue. I wish it was. If you look at the pedal you can see it would be hard to get the mat up there. I think I will opt for putting it in neutral. At least I can steer. Thanks for all the helpful info. |
12-05-2005, 09:38 PM | #7 | ||
Re: Re: Re: Re: gas pedal sticking
Why?
12-06-2005, 12:44 AM | #8 | ||
Re: Re: Re: Re: Re: gas pedal sticking
Would it hurt it as bad to down shift, 2nd, 1st, while applying the brakes, as you slowly pull over? If the gas pedal itself is not sticking, could this have been some strange malfunction with the cruise control maybe setting on its own? (maybe the computer reset fixed it?) |
12-06-2005, 08:19 AM | #9 | |
Because if the RPM's start increasing at least the car isn't in drive. Maybe this isn't necessary. I want my 1977 Datsun B210 back!!!
QUOTE=Schurkey]Why?[/quote] |
12-06-2005, 09:14 AM | #10 | ||
12-06-2005, 12:07 PM | #11 | ||
Re: Re: Re: Re: Re: Re: gas pedal sticking
Do you have both problems? Or just one or the other?
05-08-2007, 12:03 PM | #12 | |
gas pedal sticking
My car is having a problem with the gas pedal getting stuck. When I come to a complete stop, and then try to go, my gas pedal is stuck. I have to stomp on the gas to make it go and at most times is gets so bad that the tires spin. This is a serious problem and I have tried to use WD-40 but it doesn't help. It got so bad during rain that my car almost spun out of control. Can anyone tell me what this could be????
05-09-2007, 07:38 AM | #13 | |
Sounds to me that if that occurs again and there is an accident, that chevrolet will be responsible for this occurance.
2002 LT Trailblazer 4x4 One of the first of this kind on the road 2003 3500 LT Silverado 4x4 ext cab 2006 Heritage Softail HD FLSTI |
