Go Back   Automotive Forums .com Car Chat > Oldsmobile > Ninety Eight
Old 09-30-2006, 09:42 PM   #1
frankie g
1996 olds 98 whining noise
Hi,
My 1996 98 makes like a whining noise when accelerating. I hear this on some other GM 3800's. Everything works and the car runs fine any answers?
frankie g is offline   Reply With Quote
Old 10-01-2006, 03:40 PM   #2
Alibi
Alibi's Avatar
Send a message via Yahoo to Alibi
Re: 1996 olds 98 whining noise
Is it supercharged?
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Alibi is offline   Reply With Quote
Old 10-01-2006, 07:33 PM   #3
frankie g
not supercharged, I think it's either the alternator or the fuel pump.
Thanks.
Old 10-03-2006, 10:36 PM   #4
Alibi
Alibi's Avatar
If the fuel pump has been replaced, then maybe (cheap fuel pumps whine louder than expensive fuel pumps). I'd guess water pump, but maybe alternator but the alt shouldn't loud enough to hear. Otherwise, a bad tensioner is possible.
You need to start the engine, use a bit of garden hose or a dowel rod and try to listen to each individual pulley as someone (or you) gooses the throttle.
-Eric
Old 10-05-2006, 03:10 PM   #5
brick43
I had this problem with my 1990 it turned out to be the alternator becareful the bearings failed in mine and took the serpintine belt out
brick43 is offline   Reply With Quote
