| Latest | 0 Rplys |
01-08-2009, 08:23 AM | #1 | |
to much gas
i have a 94 geo metro that has a problem spewing gas out the top of the throttle body, thought it was a blown head gasket but have installed a new one and it is still doing it help please...
01-08-2009, 08:53 PM | #2 | |
Re: to much gas
Is it coming upward from the fuel injector? Or is is being spit back out of the intake? Did you check your valves and timing? Please explain in detail...
01-08-2009, 09:26 PM | #3 | |
Re: to much gas
I think your FPR is punctured.
Holy Sh*t, you replaced a head gasket, before coming here? So sorry we couldn't have saved you the trouble, but yea....check your Fuel Pressure Regulator. It likely has a hole in it. Furtunately, they're cheap and simple to replace. Once you remove the air cleaner, you'll see a little square cap with 4screws holding it down. That is where your FPR is. I hope this helps. Leon |
01-08-2009, 09:36 PM | #4 | |
Re: to much gas
thanks, i fixed that problem, it was my timing belt out by three notches. BUT i said BUT now that i had it running great after adjusting that, i put the crank pully back on and then hte alternator belt it will not start at all. it will turn over , it is getting gas and fire, but will not run.
01-09-2009, 12:03 AM | #5 | |
Re: to much gas
Your spark plugs may be fouled.
01-09-2009, 12:39 AM | #6 | ||
Re: to much gas
oooohhhh, sorry, I'm lost now. You put the crank pully on and alternator belt and it won't run? I don't quite understand how that could have affected it. |
01-09-2009, 06:35 AM | #7 | ||
Re: to much gas
01-09-2009, 07:17 AM | #8 | |
Re: to much gas
Sorry, don't mean to be an ass, but this really stumps me too. Don't worry, I had my fun dealing with a few things, but your case looks odd. There a good possibility that your injector could even have a bad o-ring. I believe there are two of them on it and if any one of them go bad, then it will spew out gas.
