| Latest | 0 Rplys |
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
12-19-2004, 10:25 AM | #1 | |
traction problems
finally i got my clutch installed (rps max) and i have the hole exhaust system. down/test pipes running 2.5" to my mufflers. i couldnt find any muffler that i really like so i went to ASSA racing and the owner there hook me up with two turbo exhaust. anyways,so i have this set up and of coarse firt gear i'm burning tire. 2nd gear i can feel Z tillting one way. i'm putting to much power that my tires can get a grip on. any sugestions?
this is my entire setup: ECU (JWT) SGP POP CHARGER (JWT) UNDERDRIVE PULLEY( SGP) RPS MAX CLUTCH WITH STREET DISC DOWN PIPES (SGP) TESTPIPES TURBO EXHUST (ASSA RACING) |
12-19-2004, 02:55 PM | #2 | |
Re: traction problems
do you have stock wheels? if so, i would get some wider wheels, more rubber on the ground is always a good thing.
-Jared
ZedEx Crew Member #2 |
12-19-2004, 03:32 PM | #3 | |
Maybe a strut tower?
12-19-2004, 03:59 PM | #4 | |
I would recommend reinforcing your car at this point.
12-19-2004, 04:08 PM | #5 | |
I Look For Wider Tires But The Wides I Can Go On A Stock Rim Is 255/50 16 Which Is The Next Tire Up In Size.
So Adding A Strut Bar Makes A Diference? Its Like I Cant Even Drive It Hard Cause It Will Stir Side Ways On 2nd Gear. |
12-19-2004, 04:44 PM | #6 | |
You could go TT wheels for all for corners then.
12-19-2004, 07:18 PM | #7 | |
TT wheels, good tires.... BF Goodies.... or Michies, or even Goodyears.......... solid brands Z rated a must, prepair to pay good money for them too. Lastly sounds like you need a better rear end. perhaps a better LSD.
Finaly got pics of my car....... after I washed it of course. |
12-19-2004, 08:53 PM | #8 | |
My Z Is Tt! Maybe Wider Tires But For That I Will Have To Upgrade My Stock Rims To 17 Or 18
12-20-2004, 01:28 AM | #9 | |
Z Cars Fanatic
what kind of tires do you have on there now??? throw on some nice tires in the rear, that should work wonders and if you really want soem traction for the straight-a-ways, throw on some drag radials but dont expect to handle corners at 80mph.
ZedEx Crew Member #4 |
12-20-2004, 09:14 AM | #10 | |
Don't drive as hard? Have your grandma drive and learn how the pros get traction.
12-21-2004, 02:34 AM | #11 | |
Z Cars Fanatic
i have another thought of why you may be losing traction so easy...
is it really cold in your area, when it is really cold in my area my tires on my N/A spin through 1st gear...i think its because both surfaces are so hard and solid, makes it hard for the rubber compound to sink into the asphault...
12-21-2004, 05:32 AM | #12 | |
Its A Little Cold But Not As Cold As Up North. But Your Right That Is A Factor.
12-21-2004, 12:28 PM | #13 | |
Ok as for tire and wheel size try 18 X 9.5s that will make a HUGE difference in traction in the rear. Also I do suggest the LSD if you do that and a bushing deleation kit.
