| Latest | 0 Rplys |
02-05-2006, 09:50 AM | #1 | |
Need some answers
Hi i,m new to the forum and found lots of info on various questions but not quite what i was looking for. I have a 1999 cavalier 2.2l with 156k. I had the head reworked, because my own carelessness the head warped. Everything went perfect with the installation and when we finally started it up it ran perfect, like a new engine. While it was running we noticed a fuel leak at the fuel filter. After fixing that problem we had problems starting it. We replaced the filter and it started right up. It idled really smooth until we revved the engine a little. it started to cough and sputter when it returned to idle speed then it died. Trying to restart the car it was acting like it was starving for fuel. After letting it sit for about 20 minutes we restarted it and it idled smooth, but when we revved the enging it runs smooth until it returned to idle then the coughing and sputtering starts then it dies. Help this is diving me nuts!!
02-05-2006, 07:17 PM | #2 | |
Re: Need some answers
sounds like sock in gas tank is collapsing. also fuel pump could be defective or leaking. sock (filter) in gas tank is probably the problem. you can and should replace it might as well replace pump in tank while you have it down, or you can just rip the sock off (not recommend this) or you have a leak in one of your fuel lines when you did your other work.
PIETRO |
