| Latest | 0 Rplys |
08-19-2014, 04:23 PM | #1 | |
00 1500 air bag light came on
hi
I was driving my truck and then started binging and I looked at dash and the air bag light lite up what does this mean what would be wrong |
08-19-2014, 07:06 PM | #2 | |
AF - Advisor
Re: 00 1500 air bag light came on
Get it scanned free at your local chain type auto parts store.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
08-19-2014, 07:10 PM | #3 | |
oh they can read it?? for air bag
I did pull the fuses out and pushed back in seems to fix it for the moment but how do you also get those fuses out they are held on with plastic yellow bracket cant get damn thing out even if I had to replace it so my innoa scan tool can it not tell? or needs special scan tool |
08-20-2014, 05:35 PM | #4 | |
AF - Advisor
You can ask.
My Innova won't read it, just some ABS (not Dodge though) and general DTC's.
08-20-2014, 09:07 PM | #5 | |
ah ok ill ask I know Canadian Tire charges like 30-40 bucks to read codes for you
that's why I bought the innova at the time and for curiousty how do you remove the fuses from those holders when you cant pull the plastic part out and pulling the fuse out and pushing back in fixed the issue but as soon as I started to drive or turn friging light came back on |
08-20-2014, 09:16 PM | #6 | |
2 Rows over from arrow and down. White plastic tool for fuse removal.
Post back, that's what makes Forums Work. |
08-20-2014, 09:22 PM | #7 | |
mine different
my Airbag is inside the truck on the side of the drivers side, has a a fuse for driver and passanger but it has a yellow plastic holder around it, you can pull out the yellow holder so far but you cant remove it as I wanted to see if fuses were blown but it lets me pull out the fuse till the plastic holder but no further there is a black one in there too that does something |
