Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-29-2014, 02:19 AM   #1
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
1988 318/5.2 runs rough and stalls when hot
Truck in question has 175k, is the TBI version (fuel injected carburetor design), has had the plugs cap and rotor replaced fairly recently.
When cold, it starts and runs normally. As it warms (after around 20 miles) it starts running rough, then after getting warmer/full operating temp, it will stall at stop signs and runs very rich - so rich you can smell the unburned fuel. At this point it is also difficult to start and requires adding some gas pedal.
I am thinking a vacuum issue, or something that is not allowing it to transition from the warm up cycle to normal cycle.
Any thoughts or suggestions would be appreciated.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
fredjacksonsan is offline   Reply With Quote
Old 06-29-2014, 02:10 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: 1988 318/5.2 runs rough and stalls when hot
Check for good ignition spark during stall condition w/spare spark plug.
My young'un had the same problem on a camaro...bad ignition coil.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
