Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-19-2010, 06:31 PM   #1
iroc343
no start TPI
91 Firebird 305 TPI quit running, 40psi fuel pressure, good spark, noid shows injectors firing. Changed cap, rotor, ignition module, fuel filter. Tries to fire, but won't catch, I'm out of ideas. Could it be plugged catalytic converter?
iroc343 is offline   Reply With Quote
Old 10-19-2010, 07:50 PM   #2
iroc343
Re: no start TPI
Just pulled the catalytic converter off and still no run. Acts as if it's not getting fuel. If I spray carb and choke cleaner in the throttle body it'll run till that's gone. It's got fuel pressure and the injectors are pulsing, what could it be?
Old 10-22-2010, 01:07 PM   #3
iroc343
Re: no start TPI
Finally have myself convinced it's a bad prom. Got the bugger started and tried to set the timing, timing light is erratic, strobes 8-12 times then off for 8-12 cycles. Since the input is the same for the injectors and the timing I've concluded that the prom is malfunctioning. Anyone else encountered this?
Old 10-25-2010, 08:04 AM   #4
wrightz28
is bring'n sexy back
wrightz28's Avatar
Re: no start TPI
I would have the ignition control module tested first.
wrightz28 is offline   Reply With Quote
87 2WD Pick Up - Two Decades of Starting Problems MSW78 Older Pickups 5 11-21-2009 09:45 AM
Hard Start...Lifters knockin after start-up for like 2 min. 2000 Chevy Silverado 5.3L Silverado_Dude Silverado 8 08-21-2009 07:28 PM
2003 Malibu starts but stalls immediatly? the_unicycle_guy Malibu 21 07-24-2009 11:48 PM
97 yukon wont start yukon45427 Yukon 1 06-23-2009 07:24 AM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
