| Latest | 0 Rplys |
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here. |
01-16-2008, 06:43 PM | #1 | |
transmission problem
help please, I have a 1995 z28 LT1,w/auto transmission that shift reverse only, no drive gears what so ever. I shift to drive car doesn't move I rev it nothing happend. the idel changs when shifting from N to D drive but car doesn't move. previus owner said that happend while he was going to work , no warning or anything.
anybody have an idea of what causing this? or is the transmission shot? thanks |
01-16-2008, 08:34 PM | #2 | |
Re: transmission problem
thats weird..... when a tranny goes, normally its reverse that goes first..... that being said, im not a trans guy by any means, i paid a guy to build mine for me.
but it would seem to me that if you have reverse, and the car moves, your clutches and bands are transferring power, which means i would guess (definatly just a guess) that something is wrong in your valve body. there are a helluva lot of check balls and springs and little things that can go wrong. maybe something is stuck somewhere, not allowing pressurized fluid to get to the rest of the tranny. The good thing here is that if it is just the valve body, it should be a relatively cheap fix. The valve body can be removed with the tranny still in the car i believe. If it were something else, say the fluid pump, the whole tranny needs to be removed. But dont quote me on that. the tranny might have to be upside down now that i think of it, and that would require its removal. hopefully someone with some more experience will be able to pipe in here.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
01-16-2008, 09:19 PM | #3 | |
thanks for the info.
I'll drain the trans. oil tomorrow and see how it looks. to see if I can get more info on it it's self. |
01-16-2008, 09:32 PM | #4 | ||
eBay aDdict™
- Jason 1995 Pontiac Firebird User Guidelines | VB Codes Explained | AF Merchandise "Each of us, is in the scheme of things, insignificant. But millions of insignificant people, doing a tiny bit, can add up to be a very significant force." |
01-16-2008, 09:54 PM | #5 | |
the previus owned had changed the oil and filter to the trans. but that havent changed anything. but he said that the old fluid almost looked like burn motor oil that it looked dark and thick. so I am thinking it might have clogged some lines or something. is there anyway to flush a transmission? and how?
thanks |
01-17-2008, 08:04 AM | #6 | |
AF -Advisor
More than likely, it has fried the forward clutches. If the fluid came out burned, it's gonna take more than a "service". Electronically controlled transmissions of this type can have failures when a solenoid or "switch" goes bad, not allowing proper "channeling" of the fluid. Inadequate pressure gets to the clutch pack, and it slips, eventually cooking it.
I'd bet, if you pulled the pan, there will be more debris in there, and the fluid will be black agian. Sorry dude, but a rebuild is in your future. Make sure the shop is familiar with computer-controlled transmissions and they test EVERY switch! Jim |
01-19-2008, 01:13 PM | #7 | |
take the tranny out buy a banner kit should be arround 70 bucks, a new band 20 buck (hd version), the 3-4 piston (that one kill my tranny twice) 20 bucks, a few beers and a friend that knows how to rebuild trannys, and you are good to go, honestly rebuilding a tranny its nothing from other world you just need a good internet source a lot of patience and a clean space to do it
01-20-2008, 12:47 PM | #8 | |
thank you guys for all the info. I went to the trans. shop mechanic told me that the cluches are not good anymore and that the oil smiled burned. he recomended me to rebuild it. I told him to do so and install a shift kit. he will change all the switches all cluches and install shift kit for $700 dollars. I priced a tranny at a junk yard will cast me $650 dollars. the mechanic works at a college he is a teacher in mechanics.
so what do you guys thik I am I being charged too much or is it the right price for doing all that? thanks again for the help. |
01-20-2008, 01:35 PM | #9 | |
700 $ with shift kit and he removes and puts the tranny back, its a really good deal, but make sure thathe puts new seals and the 3-4 piston cuz that piston had burn my tranny twice good luck anyway
01-20-2008, 01:46 PM | #10 | |
I am not really sure what the 3-4 piston is but he is going to put everything new. but I'll call him and make sure with him anyway.
thanks |
02-11-2008, 03:28 PM | #11 | |
thanks guys for all the help,
I got the car back from the mechanic last week and the car shift smothly. shift kit is noticed when stepping on the gas . the reasone for the trans. to stop operating was one of the pistons cracked and leak trans. oil . but now the car runs good. as I bought the car only engine running not trans., I didn't now how fast the car was but now I find out that the car has great power. thanks again. |
02-11-2008, 04:10 PM | #12 | |
Will Whore For Car Parts
good luck, nice to see another car up and running
1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
