Go Back   Automotive Forums .com Car Chat > Car Audio
Old 03-08-2007, 10:02 PM   #1
ab4u
Exclamation Any Professional Help Will Be Greatly Apprecitated
I have 2 audiobahns 12" subs with 400rms each. Yes thats 2 audiobahns.. i need to find an amplifier that will power these 2 nice but i dont know what rms wattage amplifier to get... also is MA AUDIO AMPS any good ? because im not looking to buy a really expensive amplifier so let me know if they are any cheap amplifiers out there that are really good quality I dont want to blow up my alternator and upgrade my engine parts so please keep that in mind when suggesting...Please reply asap thanks
The specs for my subs.. please dont crticize on my subs because i already have them thanks
12" High Performance Subwoofer
45 OZ. Strontium Magnet
2" 4 Layer Black Aluminum Voice Coil
400W RMS Power Handling Per Sub
800W RMS Power Handling Per Pair!
24Hz - 1kHz Freq. Response
92.1dB Efficiency
Bumped & Vented Polished T-Yoke
Poly Coated 2 Layer Non Pressed Paper Cone
Lug Lock Terminals
Dual 4Ω Voice Coils Per Sub
1 Ohm or 4 Ohm or 2 Ohm Stereo Operation
Rubber Gasket & Magnet Mesh Cover
5-1/4" Mounting Depth
ab4u is offline   Reply With Quote
Old 03-08-2007, 10:20 PM   #2
pimprolla112
pimprolla112's Avatar
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: Any Professional Help Will Be Greatly Apprecitated
Ebay, profile, hifonics, autotek, PPI.
Also to power the subs anywhere from 400-800 for the both will do fine. But we cant suggest an actual amp unless you can tell us whether you have DVC or SVC subs and whether there 2-ohm or 4-ohm. It should say on the basket of the sub.
And MA audio makes decent amp but they rate there power levels at 18volts last time i checked, your car will never go over 14.5v under normal operating conditions.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
pimprolla112 is offline   Reply With Quote
