| Latest | 0 Rplys |
02-01-2006, 11:09 AM | #121 | |
Re: How many miles do you have your Isuzu?
2004 Rodeo
3.5 L 25207 miles I have had my Rodeo since it had 22000 miles. I love my SUV!! |
02-02-2006, 11:19 PM | #122 | |
1996 Rodeo 4x4 Manual
3.2L SOHC V6 144,470 Miles Just bought the rig 2 weeks ago. Had no 4WD. Found bad Vacuum Switch on actuator. While under the truck, found ALL FOUR CV boots split in two! Needless to say, the vacuum switches cost $177.00 (for the set) from the dealer and I'm replacing both axles ($65 a side). Other than that, it's been a good ride.
Jason 2003 Grand Cherokee Laredo 4.7 L V8 4x4, Auto Trans. Rochester, MI |
02-07-2006, 10:36 PM | #123 | |
1997
3.2L V6 106,000 Replaced exahust system with a flowmaster. Alt. and bumpers died due to "opperator error" |
02-08-2006, 01:26 AM | #124 | |
1998
3.2 v6 102,000 all original except alternator, belts, rear axle seal
Vlad 1998 Rodeo V6 5spd |
02-09-2006, 10:53 PM | #125 | |
1995
3.2 |
02-10-2006, 11:18 PM | #126 | |
1994 Rodeo 3.2
180k
Bryan Campbell |
02-11-2006, 01:08 PM | #127 | |
1995
3.2 V6 99,500 miles No major issues. Minor issues: Stuck rear door, rear brake light stuck on, alarm goes off every time you open or close door. Othe rthan that so far so good! |
02-14-2006, 03:45 PM | #128 | |
1996
3.2 122,584 Timing Belt Water Pump Starter O2 sensors twice Rotors (and lug bolt) front axles (boots ripped) 2 windshields Still looking for a usable cupholder really considering mounting one with screws into the passenger side of dash. Last edited by themkl; 10-04-2007 at 05:29 PM. |
02-16-2006, 11:31 AM | #129 | |
1995
3.2 206,000 Problems, Y-pip, 1 Starter, 1 injector failed, Rear spring bushings, (Common Problem, makes knocking noise around corners, Easy fix, $10 for bushings) Timing belt tensioner failed after 4th belt, Power door locks needed greasing, rear power window return spring rusted out, easy fix. Original CLutch, Alternator, Exaust. |
02-20-2006, 04:09 AM | #130 | |
1995-2wd
3.2L 31,000 actual mileage, mom only went to grocery store 1/2 mile, still has original tires. Re-occuring latching/unlatching problem with rear liftglass; electric window problems on driver & rear pass. side units; last week replaced battery but found it's starter problem, time to order factory service man; B-day present for mom before her unexpected passing-30,000mi. service done by dealer=$1,193.22 - I declined to replace serpentine belts @ $450 & minor valve cover leak @ $750; (I'm in the wrong trade) |
02-20-2006, 01:48 PM | #131 | |
1997 Rodeo
3.2l v6 sohc 111283 Miles Major issues: I have this never ending pain in the lower part of my back. I wasnt hugged enough as a kid I like broads with glasses oh wait not those kinds of issues...NEVERMIND!!! See my post regarding fuses!!!
1998 Chevy Blazer LS 4x4 1996 Ford Dunderbird LX 3.8L |
02-21-2006, 09:20 PM | #132 | |
Year: 1999
Engine: 3.2L V6 M/T Mileage:111,000 Any major problems: Nothing major (fuel press reg, front stabilizer bar links, driver's side exhaust flange weld crack, starter) So far, it's all good. Mark dingo01@verizon.net Huntington Beach, Ca. |
02-24-2006, 12:40 PM | #133 | |
2000
3.2V6 121K Only problems are burning fuel badly, CEL, and gas light flashing at 1/4 tank. Any ideas before I head off to the mechanic? |
03-22-2006, 07:21 PM | #134 | |
Year:1996
Engine:3.2 V6 Mileage:145000 Any major problems: Will say i have no gas when i have gas and meter will drop and not want to start.(still have this problem) Iv replaced stereo, speakers, add'd a sub, (sounds nice) Alternator, battery, changed fluids,brakepads and iv got the fuel flter next to me ready to install |
03-25-2006, 06:01 PM | #135 | |
Update: 150K on the 3.2L V6 auto Rodeo LS 4x2
Major problems: coolant leaks from o-rings sealing ends of external cooling pipes on top of block and freeze plugs between the block and tranny housing. I don't consider broken window regulators or failed starter as major problems. Main reason for the update? 4L30E performing flawlessly at 150K! |
