Go Back   Automotive Forums .com Car Chat > Lincoln > LS | MKZ
Old 07-15-2010, 11:12 AM   #106
darkvader91
Re: codes P0171, P0174 Lincoln LS V6"
Could you add me to the list of those needing the pdf instructions. email is mspruellatmi-connection.com.
Thanks Much!
darkvader91 is offline   Reply With Quote
Old 07-15-2010, 12:47 PM   #107
shorod
SHO No Mo
shorod's Avatar
Thanks Much!
The files should be in your inbox. Good luck!
-Rod
shorod is offline   Reply With Quote
Old 07-15-2010, 01:56 PM   #108
mrlizardguy
Hi Rod,
I need the pdf instructions. email is vwsmurf@gmail.com. My mechanic removed part of the elbow but part is still there - is it indeed an elbow? There was definitely a vacuum leak there. Thanks!
Chris
mrlizardguy is offline   Reply With Quote
Old 07-15-2010, 05:39 PM   #109
shorod
SHO No Mo
shorod's Avatar
Originally Posted by mrlizardguy View Post
Hi Rod,
Chris
The files should be in your inbox. I'm not sure how the shop could have removed part of the elbow without either replacing it or putting it back together with a huge vacuum leak.
-Rod
Old 08-05-2010, 05:50 PM   #110
BagpipesActual
Hello All,
Wow, what a wonderful forum. I am no mechanic and this is my first ever post so i hope I'm following proper etiquette and sharing the right info.
I own an 04 Lincolns LS V6. I have tons of issues with the car. I learned on some other threads that I could take it to an auto parts store and get free diagnostics done.
I got 5 codes back....discouraging
p0305 - Cylinder misfire detected cylinder 5
p0174 - This is the one that led me to you great people
p0430- Catalyst efficiency low bank 2
p0316 - Crank sensor condition
p0353- Ignition Coil
Again I have not researched the forum yet on each of these just the 174 which led me here. I will try and request info on the other codes in the right threads.
Rod could you please send me the pdf instructions as well.
sharpe.matt@gmail.com
Thanks kindly,
Bag out
BagpipesActual is offline   Reply With Quote
Old 08-05-2010, 10:06 PM   #111
shorod
SHO No Mo
shorod's Avatar
Welcome to the forum!
Files should be in your inbox.
-Rod
Old 08-07-2010, 06:31 PM   #112
spaz192
Mine was the rubber elbow. It was sucked in on the bottom side with a hole. It also was soft and brittle.
If you take the guidance Rod has with a little mechanical skill and take your time this is striaght foward and easy.
Thanks Rod
spaz192 is offline   Reply With Quote
Old 08-15-2010, 08:18 PM   #113
portorikin
-Rod
I am also ready to tackle the pcv elbow replacement on my 01 ls v6. Ive been going nutz for 2 years with this. Car has been parked for 3mnths now. I cannot pass inspection. Could you please send me your pdf instructions for this job? My email is perfboy@excite.com.
thank you.
P....
portorikin is offline   Reply With Quote
Old 08-15-2010, 08:38 PM   #114
shorod
SHO No Mo
shorod's Avatar
-Rod
Old 08-15-2010, 08:53 PM   #115
portorikin
Thumbs up Re: codes P0171, P0174 Lincoln LS V6"
-Rod
I will try this ASAP. I will update this as soon. Thank you for the files.....
Old 08-16-2010, 05:52 PM   #116
maxmark13
Rod- Having the same issue on my '02 v6, could you please send me the files. bmaxwell13@gmail.com
Thanks!
maxmark13 is offline   Reply With Quote
Old 08-17-2010, 01:00 AM   #117
ericoler
I have a 2000 LS and have the codes P0171 and P0174 system too lean please send me pictures on how to repair this code thanks ericoler@netscape.net
ericoler is offline   Reply With Quote
Old 08-29-2010, 11:07 AM   #118
mbaughman
Rod, looks like you are the go to guy on these instructions. I know how much easlier they will make attempting this job. When you get a minute, can you email me the pdfs as well. I sure would appreciate it.
Thanks
Matt
mbaughman is offline   Reply With Quote
Old 08-29-2010, 11:18 AM   #119
shorod
SHO No Mo
shorod's Avatar
Thanks
Matt
I'll let you read back through the posts and tell me what information you left out.
-Rod
Old 09-07-2010, 03:32 PM   #120
reefkprswife
These codes are on my 2002 Lincoln LS along with p0153, p1131 and p1151. It started with the check engine light on and ideling rough, so I read the codes. I found this site while researching the cause of these codes and found it very informative. It is now missing while driving so a friend has offered to help me change the pcv valve.
I would like to get the pdf instructions if I could.
The car is also doing other wierd things, which may be caused by the fuse box. Yesterday when I turned it off, the parking lights and tail lights would not go off, and today the blower motor stayed on after the car was off and the key was out.
reefkprswife is offline   Reply With Quote
