Go Back   Automotive Forums .com Car Chat > Toyota > Sequoia
Old 11-23-2011, 12:05 PM   #91
alexander_thompson
Re: Program Toyota Master Key
i found it very easy to reprogramm my avensis key using this guide here: http://www.autokeysquad.com/toyota-fob-programming
hope it helps you as well
regards,
alex
alexander_thompson is offline   Reply With Quote
Old 01-28-2012, 05:44 AM   #92
thaerkhalil
To all those who tried these steps and didn't work for them, I am tilling you the secret is to push the key in when you switch between on and lock. I can assure you, It will work. I figured that out after many trials.
thaerkhalil is offline   Reply With Quote
Old 01-28-2012, 02:45 PM   #93
thaerkhalil
Any key that start the car, it considered as Master too. I programed mine from a duplicated key. Good luck.
Old 02-01-2012, 02:06 PM   #94
mmnicklaw
I have a 2002 Toyota Camry and only have one valet left. I have purchased a key online and had it cut. Is there a different series of steps to program a new key from a valet key vs. A master key as the steps above don't seem to work. Security light never goes off after completing the steps. Any ideas?
mmnicklaw is offline   Reply With Quote
Old 02-14-2012, 11:44 AM   #95
lorikost
@Mysequoia03
Please email me the manual instructions for flashing the system and allowing a new master key to be accepted.
lorikost is offline   Reply With Quote
Old 02-14-2012, 11:45 AM   #96
lorikost
@Mysequoia03
Email address is csrkoster@yahoo.com
Old 06-06-2012, 03:01 PM   #97
vrodama
Hi there.
I have a 1998 Landcruiser with both black remotes and the grey key, but the remotes no longer work even with new batteries.
According to the dealer, the ECU/ECM needs to be replaced. After reading this forum, I doubt anything the dealer has to say.
My situation: The black remote no longer work. We only use the grey key to open and start the vehicle, but every time we open the doors, the alarm goes on and the only way to turn it off is by inserting the key and turning in to the on position or by turning on the vehicle. While driving the vehicle, the door locks, lock/unlock themselves continuously, especially when pressing the brakes.
Lately, we are having trouble starting the vehicle. While turning the switch, we get absolutely nothing. It will start only after we move the shift up and down a couple of times and press the break pedal a couple of times. Is this an indication that the ECU/ECM needs to be replaced? Any help would be greatly appreciated.
Thank you.
Vrodama
vrodama is offline   Reply With Quote
Old 11-17-2012, 08:23 PM   #98
donnapoe
Would you please send me the instructions for programing my transponder key.. I have a 2007 Toyota Camry. The key has been cut, I just need to program it. What about the lock/unlock buttons on the key? how do i program them? please send to donna_poe73@yahoo.com Thanks!!!!
donnapoe is offline   Reply With Quote
Old 04-02-2014, 01:17 PM   #99
evarodz
Hi, I try several times to program a new key for my Toyota sequoia 4x4 limited 2003 manufactured on 10/2002 with both procedures (accel./brake pedals and door/ignition) but I can't succesfull. Could you help me and if yes can send me the procedures to my e-mail. (evarodz@hotmail.com)
evarodz is offline   Reply With Quote
Old 07-28-2015, 08:20 PM   #100
Woodlily
I have a valet key only for my 05 toyota matrix. I have two new keys and need to program them. Would you please send instructions to tammystehr@gmail.com?
Thanks in advance.
Woodlily is offline   Reply With Quote
Old 08-31-2015, 08:44 PM   #101
ironsave
Good Evening all.....
Just wanted to share my experience with programming a new key and fob.
2003 Avalon XLS.
The 2003 instructions did NOT WORK. I tried this 5 times.
The 2002 and previous did work on the first try. (Gas pedal and brake method).
The fob was also accomplished using the insert key twice, open close door twice, etc.....
Thanks to original poster.
I would say if anyone is having issues with 03, try the older instructions.
Toyota will cut a key (bought on eBay) for free, just give the vin number for a more accurate cut versus trying to trace a worn out key.
Good luck to all.
ironsave is offline   Reply With Quote
Old 01-26-2016, 10:41 PM   #102
radicalbill
I need to replace the Anti-theft ECU on a 99 Avalon, which is separate from the ECU main computer. I think the transponder data is stored in the ECU, not the anti-theft ECU on this model.
Am I correct ?
Otherwise, does anyone have a link to where I can find the correct programmer and software for reprogramming the Anti-theft ECU ?
Thanks
radicalbill is offline   Reply With Quote
Old 01-27-2016, 05:51 PM   #103
jk3521
Please!! I am looking for instructions on programming a new transponder key for a 2006 Toyota Solara. Any help would be appreciated.
jk3521 is offline   Reply With Quote
Old 04-23-2016, 08:41 PM   #104
fredt140v
I would also like any help / instructions about transponder keys and how to.. I have lost all the keys for my 2001 Toyota Camry GL station wagon. I have had quotes ranging from $650 to $3000 to have it done the lower end by a locksmith that would come to the car and do it on site , the higher end I would have to get the car towed to them . I am very mechanically apt and know I could do it if instructed properly. So if the PDF that is offered to be sent is for my car please send me a copy and any other relevant info for this task. cheers email to fredt140v@gmail.com
fredt140v is offline   Reply With Quote
Old 01-29-2017, 01:48 PM   #105
Coucouroucoucou
Hello
Is it still possible to have the pdf document Mysequoia03 was talking about ?
My email is eloise.dupont@gmail.com
Thanks a lot !!!!!!!!!
Coucouroucoucou is offline   Reply With Quote
1999 Toyota 4Runner Key Problem mmahan69 4Runner/GX470 1 02-03-2011 12:30 AM
2005 toyota camry LE master key and remote programming ny17 Camry/Camry Hybrid/Vista 2 06-23-2009 04:50 PM
'04 Master Key duplicate programming steps? solara04nubie Solara 1 04-21-2008 12:30 PM
program master key 2003 camry sequence? camry03 Camry/Camry Hybrid/Vista 0 09-30-2004 10:09 AM
