Go Back   Automotive Forums .com Car Chat > Dodge > Viper | Viper SRT19 Roadster
Old 02-11-2003, 12:19 AM   #76
treynor
Right, I use ET streets because (a) they're legal to drive on the street and (b) they don't make ET drags in the size to fit the Viper.
FWIW too, I've run 1.8 60's on the stock street tires. It takes some practice, but it's quite doable.
Cheers, Ben (Fast Viper, Slow Viper, and some other motorized stuff)
treynor is offline   Reply With Quote
Old 02-11-2003, 03:53 AM   #77
FNG
I was talking about dohcneon. 1.8 on street tires in a FWD.
FNG is offline   Reply With Quote
Old 02-11-2003, 07:18 PM   #78
DOHcNEON
Street tires as in BFG drag radials, i have them on all fours. I know its stupid but you cant cruise around with 22in slicks.
1998 Dodge Neon
2.4 dodge stratus motor.
Hahn Racecraft stage 4 turbo with front mount intercooler.
JE Pistons 8.8:1 compression with eagle rods
bored .20 over
60mm TB
balanced and blueprinted engine
custom blackdog race ported head
Custom ground crane cam
Crane racing valve spring and retainers
unorthodox Underdrive pulley
AEM cam gears
MSd ignition
magnecor wires
iridium plugs
custom borla exhaust
stage 2 racing axles
Clutchmasters stage 4 clutch
fidanza lightened flywheel
17" rims
DOHcNEON is offline   Reply With Quote
Old 02-11-2003, 07:28 PM   #79
FNG
If youre getting 1.8's on street drag radials, I wanna see what your 60 foot is on slicks. I read that your car is put up for the winter so ill wait till spring, if I remember about this thread.
Old 02-11-2003, 08:23 PM   #80
DOHcNEON
oh you will. yes my car is up for the winter. But you see i dont go to the track much. I went once and that is where i got my 1.8 times. But hopefully i will do it on slicks. dont worry i will keep ou posted. peace
1998 Dodge Neon
bored .20 over
60mm TB
AEM cam gears
MSd ignition
magnecor wires
iridium plugs
17" rims
Old 10-09-2005, 08:05 PM   #81
carcrazy16
Re: beat a viper
vipers suck. 8.3 liters for 500HP wow nice engine. And don't say "u cant handle the power" b/c those guys who can handle the power spend hours working on handling these bad suspensioned cars that probable cost around $20g to make
carcrazy16 is offline   Reply With Quote
Old 10-10-2005, 12:45 AM   #82
Jetts
Jetts's Avatar
Send a message via AIM to Jetts
Re: Re: beat a viper
nice 2 year old thread!
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Jetts is offline   Reply With Quote
Old 10-10-2005, 07:50 PM   #83
Jaguar D-Type
Banned
Hp/liter is just a number.
Jaguar D-Type is offline   Reply With Quote
Old 11-18-2005, 12:16 PM   #84
mark grant
viper's ha ha ha ha ha
i have a 1969 buick riviera with a 455 (rocket) that will make any viper look like it's standing still.i think when bill gates said that the auto industry has not advanced enough he was right on the button.my car is 36 years old and has more capabilty to produce more horse power than most 2005's.
mark grant is offline   Reply With Quote
Old 11-23-2005, 12:40 AM   #85
Jaguar D-Type
Banned
Cars made in 2005 have to comply with emissions and safety regulations on a level not like that of 1969 cars.
Can your 1969 Buick make close to 1,000 hp?
Fast Vipers
Or go 235 mph like the 2005 Saleen S7 Twin Turbo?
Road & Track September 2005
0-60 mph: 3.4 seconds
0-100: 6.3
0-150: 12.1
0-200: 23.4
100-150: 5.7
100-200: 17.1
1/4 mile: 10.8 seconds at 138.7 mph
1/2 mile: 16.5 at 171.8
3/4 mile: 21.4 at 193
Full mile: 25.9 at 205.7
$555,000
2,950 pounds
3.9 pounds per hp
"This is a race car for the street, and it it's able to pull redline in top gear, Saleen says the S7 is capable of hitting 235 mph."
Old 11-23-2005, 09:15 AM   #86
mark grant
Re: beat a viper
The 455 rocket(7.5 L)
10.625 in(269.9mm) deck height
3.0 in(76.2mm) main journal
4.126 in(104.8mm)bore
4.25 in(107.9mm)stroke
output range from 210 to 400 hp(156-298 kw)
that is factory nothing done to modify it.
These engines,while being a wedge-head had a unique combustion chamber that resulted from a valve angle of only 6 degrees.This very open and flat chamber was fuel efficient and had lower average emmissions.It was the only"GM" engine to meet U.S emissions standards using a carburetor all the way to 1990.Seeing that my car is really dual exaust unlike alot of new cars made to look like they are,add two cadalatic converters and the emissions are pretty much up to par.But since you like 1000hp i would need to straight pipe it.Now let's make a recipe.add one 400 hp 455 ci engine than add straight pipes,than add a super charger,cams,bore it out and add larger pistons,throw in another charburator for flavour.For the outside of our tasty treat we'll add light aluminum rims for our front tires and for our rear posi trac tires.With this recipe it should make your 1000 friends happy.
p.s i have seen a shylark gs with a camed up 455 rocket that had to be chained to the frame as not to rip off the mounts,show me a new car that can do that and i will eat my own words. have a good one
Old 11-27-2005, 11:30 AM   #87
9ball
I love the old engines as much as anyone, but they've come a long way since the old days. Of course the 455 is capable of producing more power than most other cars on the road. It's capable of big power because of its displacement. That's not a secret. The auto industry has known how to make big power for a long time now, but the old engines don't run nearly as clean or as consistent as new computer controlled engines. How often do you drive a modern car and think "Oh shoot it's running too rich, I need to get out and adjust it"? Never. No matter what the weather, altitude, time of day, the mixture and timing are spot on.
Also, I really doubt a 69 Buick with an unmodified 455 is going to make a Viper look like it's standing still. I've driven my fair share of old cars in my family including a 67 Chevelle 396/375hp, 69 Camaro 350/350hp, and a 67 Buick GS400, and none of those cars would break a 14sec quarter. The new Viper does it in about 11.7. Late 60's GM A-bodies weigh over 3800lbs, so it would take a Buick that was a dedicated track car (chassis modification, tubbed with slicks) in order to get down in that territory.
9ball is offline   Reply With Quote
Old 12-01-2005, 11:35 AM   #88
-FROG-
-FROG-'s Avatar
Re: viper's ha ha ha ha ha
My buddy with his 10.5 tire Mustang, turbo small block 347 is consistant in the 8.30 range and has seen 7's a few times. This is the 1/4 I'm talking about on a small block Ford motor. dam..... 347, to your 455 rocket. Go Ford! anyhoo, in order to keep cars passing emissions, there will always be a stopping point in design. the automotive industry HAS advanced! Look at Top Fuel. ummmm............. can we get any faster on a V8? Normal production vehicles are designed keeping emissions in mind and that is a major factor in the progress of technology. There are also quite a few people who want to have somewhat decient gas mileage, no matter what car, and this is a factor in the motor's design. Bill gates was just probably trying to marked a product to the automotive industry and that is why he made that comment. He is a computer nerd and was probably talking about hybrid technology, not horsepower....
-FROG- is offline   Reply With Quote
Old 12-05-2005, 03:18 AM   #89
ikeyballz
Send a message via AIM to ikeyballz
Re: beat a viper
whoa, 11.9 on fwd? or u swapped out to make it rwd. thats pretty fucking awesome.
ikeyballz is offline   Reply With Quote
Viper to be discontinued? icila Car Rumors & Concepts 4 10-26-2010 09:33 AM
Dodge Viper Competition Coupe bmw2best WIP - Motorsports 14 06-17-2009 10:08 PM
2000 Honda Civic Si Beats 450hp Viper Video boostedcivicsi '96-'00 Civic 0 03-30-2005 03:24 PM
2000 Honda Civic Si Beats Viper Video boostedcivicsi Viper | Viper SRT19 Roadster 0 03-30-2005 03:21 PM
BEat a viper DOHcNEON Street Racing 28 12-03-2002 05:03 PM
