| Latest | 0 Rplys |
Tips and Maintenance Procedures Post helpful tips, maintenance guides and R&R procedures for all Buick models here. |
10-17-2010, 06:59 AM | #46 | ||
Re: 4T65E Trans Shift Hard, P1811 DTC
What brand spark plugs to include heat range/number and ignition wires are you using? Also, with an odb-ii scan tool you may be able to pull up some stored history DTCs like P0300 (random misfire) or P030X (specific cylinder misfire) to confirm.
10-17-2010, 07:33 AM | #47 | |
Good morning BNaylor thanks for the help,I know the plugs are AC but I don`t Know the #.I will get one one the guys at work to check for codes and get back to you.Thanks Again
10-17-2010, 08:38 AM | #48 | |
Is there a gasket in the accumulator that needs to be replaced??
10-17-2010, 08:49 AM | #49 | |
10-17-2010, 08:53 AM | #50 | |
Thanks for the quick reply BNaylor. Do you know if the gasket is included with the Transgo kit? Also do any of the old springs get re-installed
10-17-2010, 09:09 AM | #51 | ||
Transgo Shift Kit Pic
10-17-2010, 09:13 AM | #52 | |
However, one kit........the Thrasher shift kit does. See link below.
Click here BTW - This is the one I installed in my '97 Grand Prix GTP several years ago.
10-17-2010, 09:23 AM | #53 | |
Thanks BNaylor. I'm looking at a forum at LSTech.com that has detailed photos of the install. I think you may have referenced it in an earlier post. I still not sure what happens to the old springs. Do they get re-installed or thrown out. Also someone mentioned to me that you should reset the adapts. Do you know what this means?
10-17-2010, 09:37 AM | #54 | |
Depending on the kit the old springs get replaced with the new, if provided. The TAPS means "Transmission Adaptive Shift". Basically you get the TAPS data reset so the PCM module relearns shifting based on driving conditions/habits and other parameters. This is normally done with a GM Tech 2 scan tool at the GM dealership. Also, you can remove the battery negative cable for a few hours and this may clear the old TAPs info stored. In our '99 Regal LS disconnecting the battery negative cable worked. I have the ZZP kit in this one meaning just the spacers were used. No new accumulator springs, etc. And I used Dexron VI ATF.
10-17-2010, 10:43 AM | #55 | |
Well just got back from a 1 hour drive,I put in some gasline antifreeze engines still misses at hi rpm.But I`am liking the way the tranny shifts even the overdrive seems to be less fishbiting.I think I found the ignition problem the wires are original,bad condition.Enough for today now I`am going hunting!!
10-17-2010, 10:57 AM | #56 | ||
On spark plugs I use NGK TR55IX Iridium and/or the AC Delco 41-101 Iridium. The Delco 41-101 plugs are made for GM by NGK. Good luck!
10-19-2010, 04:13 PM | #57 | |
Great thread.
My 2003 Impala started the hard shift at about 100,000 miles, so I had it serviced a month ago. The shop stated it had never been serviced before, and since I had bought it used it didn't surprise me. The hard shift problem didn't go away, though it did improve and it showed the infamous P1811. Was prepared to lay down the required $500 when I found this thread today. I realize it won't fix the problem if the PCS if it is bad, but isn't life an adventure. Already ordered the shift kit and will look for Seafoam at a local store. Will check back later with results. |
10-23-2010, 08:12 AM | #58 | |
Good morning its Saturday and its been a week since I installed the kit in the accumulator.I just wanted to say the wife says to say THANK YOU to BNaylor the car runs Awesome !!You saved us spending $2800. for a rebuilt transmission.
12-14-2010, 10:45 PM | #59 | |
I think I may DIY also with the kit as i have same issues. One question, where is the PCS and why can I not change it also when i take the pan off? Is it just too expensive and hard to do when it could be something simpler? Thanks
12-15-2010, 11:43 AM | #60 | |
A990 racer
Inside the side cover of the trans not the lower pan, access requires a fair amount of disassembly.
