| Latest | 0 Rplys |
Diecast Car Modeling Discuss and show diecast vehicles that you have modified, or that you have collected. |
04-29-2020, 12:58 AM | #46 | |
Re: 1/8 VW GOLF GTI MK2 stance project - An italian job
While primer coat is drying on strut bars and rollacage i moved on Seats.
I removed the black paint and i stat to flock the seat. I use the self adhesive flocking (0.8 m) uded for jewel Now i'have to study how to place the "Recaro" or "Corbeau" decal on headrest. I finished the clear coat work on carbon door trim. |
04-29-2020, 12:58 AM | #47 | |
While i'm waiting the drying paint of rollcage and strut bars, i worked on seat brackets
I've seen many brackets (Sparco, OMP, Recaro, Rennsport and Wiechers), so i reproduced a custom bracket using Lego that for me are prefcet with size and shape After a quick size and fit checking, i smoothed the bracket and i holed them for a futur fixing with 1.4 nut and bolt Before to check the rollcage I removed from the rear carbon trim the central pillar cover....everything is good with good clearence I then fitted the rear and front struts bar and i think looks is goood and enhance the general view of my little GTI |
04-29-2020, 12:59 AM | #48 | |
I finished the paint work on seat bracket: 1 primer coat, 2 matt black coat and 2 final clear matt coat
To fix the barcket on floor i use M 1,4 bolts and nuts I use a longer rear bolt to fix the belts, but many friends tell me is good looking a dedicated bolts to fix them I fitted a new bolt for future belts system I made some test with 3 possible belts color: I asked to some tuning friends and model frieds. I choose finally the black belts. I think is more elegant |
04-29-2020, 12:59 AM | #49 | |
I started the paint work on body.
Before to paint i filled the hole of wiper and i removed the blanked cap for antenna on left fornt fender. So i started to dand, primer and check all....after 3 times i reached a good job to finally paint in blue. Doors and seats are finished with also 3 final coat of clear coat. Fenders and trunk only painted with 3 blue coat and need final clear coat |
04-29-2020, 01:01 AM | #50 | |
I'm continuing with paintwork and I'm arrived to bodyshell.
I removed all balck trim and stripes, i coat with primer. I check all defects and and i give another primer coat. I finallu paint the bodyshell with 4 coat of blue. I removed the iniejcton point from bonnet and i paint it with same ways of bodyshell Before to coat all with clear, I polished all with silicone remover, than i coated with 3 layer of clear I masked all bosyshell and i painted the roof trim. I meade the trim for doors, windows and trunk with rubber tape. |
04-29-2020, 01:01 AM | #51 | |
I flocked the pillars like on my 1:1 GTI
I worked on carbon door card. I add a rounf frame on manual glass knob, I add a yellow stripe to close the door and a metal wire to open the door.....and finally I adde a Metal knob to regulate the mirror. I also fitted the last rubber trim on trunk And some pics whith bodyshell and fenders mounted |
05-04-2020, 03:46 AM | #52 | |
I quite completed the hatch
i remade the rubber trim of rear glass, and also i modified the rear license plate light bar as "Cult Society" light bar like on my 1:1 mk3 I also added some PE bolts anfd paint the license lights. I fitted also the 5 point seat belts using the rear struts bar I worked on airride tank system. I machined an alu tnak, i added the inlet and outlet air connection. I assed the black rubber stripes and i fixxed with yellow belts Like one my GTI 1:1 i made the bracket for CDA of BMC. I also fitted the oil engine radiator carbon duct. When the front girll will be fitted i added the hose to duct the air to airbox and radiatore Some details (some bolts and decal set taht it's coming) and engine compartment is completed. |
05-04-2020, 03:47 AM | #53 | |
Some overall pics and some test with other rims
05-04-2020, 03:48 AM | #54 | |
I placed the viper cover adding a battery cut off swhitch.
I completed the roof trim and finally i placed hatch, bonnet and doors. Next week i hope will arrive the decal set to fianally fit chassis with bodyshell |
05-04-2020, 03:48 AM | #55 | |
I’m finally arrived to marriage chassis and bodyshell
Before make this, i stripped out the chrome from rear badge and I repainted them in semi matt black I adjusted the height of door hinges to match all panel lines I worked on tail light to match the combo color lenses of the Golf Special edition. I also flocked the inside of tail lights I also give some detail to front radiator bar: I drilled the blankes holes and repainted in titanium gold the bonnet latch. I’ll add in the future some final PE and bolts. |
05-04-2020, 03:50 AM | #56 | |
I completed the inlet air system for oil cooler radiator duct. The yellow hose start from the removesd high beam light and link to radiator duct.
To fix the metal mesh i machined the lenses of high beam light. I also add the bixenon bulb on black headlight. To reach a total dark look I black painted the mesh....i also added the PE screw for beam regulation. I did some detail work adding some head bolts on Airbox bracker and radiator bracket, at the end i completed the last air hose inlet for airbox. |
05-04-2020, 06:39 AM | #57 | |
I was arrived to the end of this long project that began almost 4 years ago with various stops and start.
During the week should arrive all decals (including license plate and VIN) and then I'll do the final outdoor photo set I worked on his home case a nd I reuse some spares parts fixxed on the wall...like on my 1:1 garage of my mk3. |
05-04-2020, 06:39 AM | #58 | |
I started the decal work to add on my model.
05-04-2020, 06:40 AM | #59 | |
I completed the last work on my GTI and now i’m arrived to the end.
I finished the work on central cap....i placed Rial because i love this brand and i didn’t like BBS. Will follow a final photo set with my 1:1 Golf |
05-04-2020, 06:43 AM | #60 | |
Thanks very much to everybody that follow my build and custom project.
This is the end of my 1/8 GTI Model: Golf GTI 1.8 8v 1988 "Road to Worthersee" Scale: 1/8 brand: Hachette italia Extra: RC 1/10 parts and Delta 1/8 seat and steering wheel , Airride tank machined by RiccardoZanelli, Decal set of Max |
