| Latest | 0 Rplys |
09-25-2009, 10:47 AM | #46 |
Re: 700R4 transmission won't upshift out of low
09-30-2009, 02:20 PM | #47 | |
I solved the sensor gear issue, and installed the trans earlier this week. when I started it today to test drive it, it makes a loud clattering sound as it is running, it can be felt on the bellhousing. I know the converter was seated properly, I double checked this before bolting the trans up. What could be wrong now???
09-30-2009, 02:25 PM | #48 | ||
AF - Advisor
Converter bolts tight? Splash cover rubbing?
09-30-2009, 02:51 PM | #49 |
09-30-2009, 03:11 PM | #50 | |
AF - Advisor
09-30-2009, 08:21 PM | #51 | |
checked the starter clearances, and all was well, I just had a thought, is it possible that I might have the flywheel on backwards (wrong side facing the convertor) would that cause the problem I am having?
10-01-2009, 08:20 AM | #52 | ||
AF - Advisor
I would unbolt converter and slide it back and then start engine and see if it still has noise.
10-01-2009, 12:43 PM | #53 | |
I unbolted the converter, fired it up,and there was no noise. I then bolted the convertor back up, and the noise was back. the number of input splines was the same,30 splines. I could feel the converter contacting the front pump tangs,so I know it's seated fully. someone told me that the starter might need shimmed, could that be the problem??
10-01-2009, 04:50 PM | #54 | ||
AF - Advisor
10-02-2009, 10:58 PM | #55 | |
I put 3 shims in, and it still makes the noise. here is a pic of the flywheel, it shows the side that I have facing the convertor:
is this right?, or does the side shown in the pic face the engine?? |
10-03-2009, 09:40 AM | #56 | ||
AF - Advisor
Does the transmission go into gear forward and reverse?
10-03-2009, 09:53 AM | #57 | |
I can feel it trying to go in gear, but the vibration noise gets louder,and becomes a higher pitch.
10-03-2009, 10:13 AM | #58 | ||
AF - Advisor
It is a internal transmission problem. Might as well pull it out and go for another transmission. Let us know how it goes. GOOD lUCK
10-03-2009, 10:52 AM | #59 | ||
Thanks for all the help! |
10-03-2009, 11:21 AM | #60 | |
AF - Advisor
