| Latest | 0 Rplys |
01-15-2008, 08:04 AM | #46 | |
Re: Blower Motor Resistor Replacement (with pics)
My fan only operates on speeds 1, 2, 3. It DOESN"T operate on High Speed.
Would this still be the resister? |
01-15-2008, 10:01 AM | #47 | |
All I know is that the resistor itself controls the 1,2 3 speeds and 4 keeps running. When I remove the resistor 4 will not work either, when I plug the old one back in 4 works...so it has to fun through there too, I would assume the resistor would fix 4 too...but all I do know is it does fix 1,2,3 when 4 works.
02-10-2008, 08:01 PM | #48 | |
have a 1999 sebring Covt.
SO SO SO EZ 1. Buy part at O reilys or Pet Boys 2. Pull out plastic molding retaining pins on lower plastic part below glover comp which covers the fan. One is dead center in the back, the other is mid right. 3. pull part out, give it a good tug. 4. Resister is on the bottom and very very ez to get to. Unplug, unscrew the two bolts (11/32), part will drop off in your had. 5. attach new one to wires 6. Stick in hole, install screws by hand, tighten them. 7. replace plastic molding by pushing towards driver side and fitting over platic heater duct. 8. push plastic molding washers in (2) from step 2, push center retaining pin to hold them. YOU ARE DONE. 15 minutes |
02-25-2008, 10:09 PM | #49 | |
Here is a picture of the heater resistor with the coating removed.
Looks like corrosion damaged the conductive traces on the board. (http://img341.imageshack.us/my.php?i...rresistec7.jpg) |
08-31-2008, 06:31 PM | #50 | |
How did you separate the wiring harness from the relay. I pushed the red tab up but it would not come completely out. Couldn't get it apart and didn't want to force it. Car is a 2004 sebring.
09-22-2008, 08:59 PM | #51 | |
Just to let you know, the repair process works well on the 2004 Sebring.....did mine today. Part is now 41.99 at PepBoys. Larry
10-08-2008, 04:57 PM | #52 | |
I know this is a really old thread, I would like to view the pics but can't seem to find them, were they possibly removed since thread is so old.
I don't have 1,2,3 but do have 4 on my 01 convert sebring. Guess I'll be getting my 8mm socket out and getting the blower motor resistor and possibly some doans for my back. Thanks for the post. |
10-22-2008, 02:06 PM | #53 | |
Will part #5174124AA work for my 06 Sebring Convertible 2.4L? I think this year is the same generation as the others mentioned here.
11-02-2008, 11:52 AM | #54 | |
I did mine today. Took me awhile (15 minutes my ass ) and you have to be a contortionist to get into the passenger floor board and under the dash, but I got it out and back in. Had to go back to Advance Auto to get help with the little red clippy thing. Couldn't get it loose and was afraid to force it. He had it apart in like two seconds then I drove back home and put it together after cutting the hole bigger. The best part is it WORKS!!! Oh yeah, it was way cheaper at Advance Auto than anywhere else. I just had to pay for it and then wait overnight for it to be delivered to the store.
11-06-2008, 07:06 PM | #55 | ||
11-06-2008, 07:08 PM | #56 | ||
11-07-2008, 10:50 AM | #57 | |
OMG thank you soooo much
i had no idea why only 4 is the fan option that was working and didn't want my heat running on 4 all winter thank you thank you thank you i am headed to the store... |
11-14-2008, 08:52 PM | #58 | |
The instructions were great and the pictures were very helpful. It took me about 2.5 hours but most of the time was spent trying to disconnect the wiring harness so I had to have my wife do this after I messed with it for over 1 hour.
11-15-2008, 09:36 AM | #59 | |
Thank you again for the instructions
i got the part and got it changed in about an hour the longest part was getting the wiring apart from the resistor my shoulder was bruised for a few days from laying up underneath there but i got it done and i am more than ecstatic that my fan blows on 1,2, and 3. thanks again it was the biggest help |
11-20-2008, 11:23 AM | #60 | ||
Yeah I think 2 years old is too quick. I think it was a rental car though as it had 34K on it when I bought it used in June of '07. I've got 63K on it now and this is the only problem so far. |
