| Latest | 0 Rplys |
Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
10-01-2006, 11:22 AM | #31 | ||
Re: Intermittent miss at light load.
10-01-2006, 11:27 AM | #32 | |
Also I would like to know what arrangment the injectors are in and how they deliver fuel.
like is there 6 of them and are they at each intake port? Do they continuosly spray fuel? just varyingthe amount? or do they turn on and off and if so are they timed? If so when do they spray, and for how long? |
10-01-2006, 11:49 AM | #33 | |
i also had a 95 blazer that did the same thing it seems like a lot of them get a slight misfire i had to change the whole fuel injection assembly it was like 3oo bucks
10-01-2006, 11:57 AM | #34 | |
I repaired a leak under plenum a number of years ago on mine, as I recollect it had a plastic line with a tiny pin hole in it and would only show up if it sat for 30 minutes-3 hrs.
My symptom is misfires between 5 - 30 minutes at very light load. When it is acting up you can see spark jumping on many of the wires. I'm tempted to put on some better insulation wires, but I'm convinced it is only a symptom of my real problem. |
10-01-2006, 01:55 PM | #35 | |||||
AF -Advisor
Running lean makes the mixture OVERLY combustable seeing it will cause PREIGNITION, pinging, and detonation seeing it will ignite too early because of the increased combustion temperatures. Quote:
You advance the distributor ONLY, not the cap and the distributor separately. The jumped to and from the cap posts is a little ridiculous bud, and you really need to rethink and relearn what you know about the internal combustion engine. Quote:
Again, you need to relearn about timing and what it means. Quote:
If you think it is the cap, then replace the cap and rotor, but other than that on a 1995, you can't touch the timing so don't even start to mess with it. I own this year and engine and I know it from stem to stern and the problem is always REALLY simple. You need to realise that you are overcomplicating this situation and ignoring the obvious and for what reason I have no clue. If the ignition system is new then MOVE ON TO SOMETHING ELSE. It isn't some ridiculous hypothesis about spark jumping in and out of posts, it is about one of three things. Air, fuel, or fire. Now that you have made sure the fire is fine, MOVE ON TO FUEL! and stop sitting there babbling on about the ignition system.
1995 Factory Blazer Service Manual for sale, PM if interested. |
10-01-2006, 07:44 PM | #36 | |
AF Premium User
after fixing the CPI i was still having a missfire on my 92 4.3. turned out to be a bad distributor bearing. i suggest tearing down the CPI and inspecting the spider assm. and checking the distributor at the same time since it will be easier to get to with the vortec plenum removed. here's a good post with lots of pics: http://www.automotiveforums.com/vbul...ghlight=spider
10-01-2006, 10:35 PM | #37 | |
Thanks, I may just do that. Was it perhaps the top bushing/bearing in the distributor housing? I broke my housing the last time from overtightening the screws and may even replace it. That is also probably what the shop was referring to when he said "worn out dist gear"
10-01-2006, 10:42 PM | #38 | ||
AF -Advisor
You don't have aproblem with your distributor, you have a problem with either the cap not being installed properly or the fuel system.
10-01-2006, 10:58 PM | #39 | |
A worn gear can cause end thrust in the shaft and some backlash throwing that rotor/post relationship off. I don't think the cap can be on wrong (other than me overtightening screws)
10-01-2006, 11:07 PM | #40 | |
AF -Advisor
And what if you breaking the screw points is not allowing the cap to seat properly and therefore is allowing moisture into the cap and causing the misfiring.
This is why after 5-10 minutes it stops as the heat from the engine drives off the excess moisture. A worn gear would cause a misfire all the time. Not just 5-20 minutes after starting the truck.
10-02-2006, 10:04 AM | #41 | |
My cap WAS bolted down as good as a new, but I will check it to make sure is still tight. A good idea about cap and moisture, that is helpful. I've ran enough water over all secondary ignition components to make an off-roader jealous and just a short drive clears up any moisture missing. I attempted to duplicate problem like that, but could not.
My problem is completely undetectable until the tork convertor locks up. That is how I assume it is going to closed loop and the very second it does is when it starts missing (as long as the vac is between maybe 10-20") It gradually gets better until about 30 minute or so and does not nessecarily have to be driven the whole time, but after the time expires the problem cannot be detected. I do have a theory about the leak in the intake, but will get set-up with a pc to verify all values to be sure. I kinda want to watch stuff oncreen while it is acting up. |
10-02-2006, 03:08 PM | #42 | ||
AF -Advisor
Don't just throw random parts and hypothesis at it, get some actual testing done. Still, have you chanecked your CPI injector yet?
10-02-2006, 03:09 PM | #43 | ||
AF -Advisor
Don't just throw random parts and hypothesis at it, get some actual testing done. Still, have you checked your CPI injector yet?
10-02-2006, 05:43 PM | #44 | ||
AF Premium User
10-02-2006, 07:02 PM | #45 | |
AF -Advisor
Hope you didn't pay for it.
You don't have to pay for them doing a trial and error shot on your truck. If you paid, you got screwed.
