| Latest | 0 Rplys |
How-to | Technical Info A wealth of information at your disposal. |
#31 | ||
Re: Fuel Injector/spider How To
Hey, John thanks for the reply. I already have it off, but your post will help with the install, If you have done this before I do have one concern before I order the update from GM Parts direct, Is this 100% the correct part # 12568332 I tried emailing them but I haven't got a responce yet, also how long does it take for them to ship it to you. |
#32 | |
Hey, John thanks for the reply....
I still have the old style injection body, but having tried to get it to stop leaking for the last 2 weeks, I see the MFI upgrade coming. So far as the nuts on the fuel lines, be sure and check or replace the o-rings when you reassemble. Good Luck John |
#33 | ||
Thanks Terry |
#34 | |
Terry
Got reply today from GMDirect. You probably heard from them by now. I picked my parts up from a dealer friend on Wednesday. Looks like it should fit perfectly, but weather hasn't allowed me to get it on yet. I/m excited about getting that old dog of an injector body out and putting the better design in. Let us know how you come out. (from GMDirect) "pk12568332" is the correct part number for your vehicle, per the VIN supplied. Thank you for choosing www.GmPartsDirect.com Subject: Part number verification **Please confirm part numbers and pricing for: 2000 GMC Jimmy 4.3 L Vin 1GKDT13W8Y2103XXX 1 each pk12568332 MFI upgrade 1 each 88894355 V6 Bracket 1 each 17113215 V6 seal kit |
#35 | |
Got the 2000 Jimmy put back together today.
MFI part numbers in above message fit/work no problem. Have other issues, but by george, my leaking fuel pressure problems are gone! John |
#36 | |
OK, I need some clarification.
When I went to change my CFi injectors origianlly, I apparently got the MFI injector. It did not look like those injectors would fit into my lower intake manifold. So does the lower intake need to be replaced as well? From the parts list you have up there, it seems not. Also the computer works the same? I do not need to replace any other of those electrical sensors? If not, that is great, but I am just curious. It definately seems the CFI has all kinds of problems and the MFI is the way to go. I replaced the CFI injectors and apparently now I have a huge vacuum leak somewhere so I need to take it all apart again to redo it to triple check what is incorrect. Since I am doing it again, I am thinking maybe do this conversion and end the issues with this fuel system. FYI, 96 GMC 5.7. Any input you all can have for me I would appreciate it. Thanks. |
#37 | |
On 2000 GMC Jimmy 4.3 6cyl W engine, the only thing I had to watch out for when putting the MFI spider in, was turning the injector connectors so that the upper intake cover would fit. Everything else seemed to go slick.
Good luck John |
#38 | |
Hi John, I just got my order in from GM parts Direct. I have run across what I hope is not a problem. All my fuel lines coming off the the fuel meter body are facing towards the fuel pressure regulator. according to the install they all need to be away from the fuel pressure regulator was yours like this or did I get a bad one? It's doesn't look like the fuel lines will turn 180 degrees. I don't want to damage it, Just wanted to know what yours looked like when you took it out of the box.
Thanks |
#39 | ||
I gently turned them around to the front without problem.That tubing is probably pretty tough, but I treated it gently anyway. Number 3 has to slip behind number 1 slightly. Position connectors like the technote describes towards manifold so upper half goes on OK, Details: http://members.shaw.ca/betterthanyou...g%20Poppet.htm Between the excellent AF How To and the tech notes. it went pretty slick. Let us hear how you came out. Good luck John |
#40 | ||
#41 | ||
Not sure about that one, Terry, but what do you think about starting a new thread on it in problem diagnosis section and let's see what the pros have to say about it? John |
#42 | |
MFI assembly 12568332
Can someone tell me if the green plastic tubes on the injectors come off. They appear to be too large for the ports. |
#43 | ||
![]() Join Date: Sep 2007
#44 | |
Yep, that's all you will need. I also bought a 1/4 torque wrench from harbor frieght to make sure I got the upper intake fastners installed to the correct in/lb rating (it's freakishly low)- I've heard this is important so you don't crack or distort your plastic intake from overtorquing thereby creating vacuum leaks. Also, buy a couple cans of throttle body cleaner as yours will probably be gummed up from underneath. It's also a good time to think of other stuff to do while you're at it, cap/rotor etc... Before you attempt the job, also check the condition of your lower intake gaskets as these are problematic with our trucks (do a search). If you'd like to replace yours with newer, better designed ones, installing the MFI is almost just a part of re-assembly of that job. Good Luck,
My favorite part about the MFI is the quick starts, two revolutions of the starter every time vs 4-6 with the old poppets! Now it sounds like-*wrowwrowVROOOOM* Actually makes me enjoy the truck more! |
#45 | |
hey guys im new to this forum specifically for this thread, as many of you my spiders went fubar and reaked havoc on my engine, would this swap take away my need of replacing all my spiders? cause from what ive learned so far there pricey and this swap dosent seem that bad to do effort wise and money wise?
