Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-11-2011, 07:19 AM   #31
IfYouAintCav
Re: 2002 Dodge Ram--P1491 fault code
Well, I hope you guys with the blown fuse are right. I got the same truck, same problem, and my fingers crossed that the fuse is blown. I will let y'all know if I have a different issue.....like a bad flux capacitor, or a blown canooter valve.
IfYouAintCav is offline   Reply With Quote
Old 01-08-2012, 12:22 AM   #32
banannaclip
i had this issue check engine lite came on,went to auto zone the checked it gave the code number then i came home googled it found this forum read past entries , its fuse 39, for the cooling fan i replaced the fuse inspected the wiring and fan found nothing abnormal see what happens not sure why the fuse blew but i saved money total cost was 4.88 for parts what would the dealer have dunno ?
banannaclip is offline   Reply With Quote
Old 04-25-2012, 08:12 PM   #33
cblockcolorado
Hey everyone - thanks for the info, I had same issue -- 1 blown fuse replacement and I'm ready to pass emissions. Thanks!
cblockcolorado is offline   Reply With Quote
Old 04-25-2012, 08:14 PM   #34
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Thanks for the update.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 07-31-2012, 08:45 PM   #35
TrucksRforGirls
I have the same problem, failed inspection in NJ for this same code. BTW, have been having this weird problem with the a/c...whenever we stop at a light/stop sign or even still moving below 30mph, the a/c gets warm, it still blows nice, but doesn't stay cold. This was seen in forums to be the fuse also....funny huh?
TrucksRforGirls is offline   Reply With Quote
Old 05-19-2013, 09:44 PM   #36
JimInTexas
Went looking on line for the cause and to decipher the fault code. Found the answers in this thread - burnt fuse. Thanks one and all.
JimInTexas is offline   Reply With Quote
Old 05-20-2013, 10:10 PM   #37
Chris Stewart
AF - Advisor
Welcome to the site and thanks for reporting your success!
Old 07-22-2013, 08:02 PM   #38
jusacarguy
Guys, 02 slt 5.9l. Same code(p1491), fuse not blown, fcm changed, controls chanded, fluids pressure correct, condensor fan works, only thing I havent changed is the compressor or pressure switch. But, heated mirrors, AC, heat,and adjuster all dont work. This is sumthing much bigger than me right now, can someone help me with this? Cause all of this failing cant come from a pressure switch nor a compressor. Heated mirrors have nothing to do with those things. Help!
jusacarguy is offline   Reply With Quote
Old 07-22-2013, 10:29 PM   #39
Chris Stewart
AF - Advisor
P1491, Radiator Fan Control Relay Circuit.
An open or shorted condition detected in the radiator fan control/relay control circuit. This includes the PWM solid state relays.
I guess the solid state relays need checking too.
Old 04-06-2014, 06:36 PM   #40
Trentac
Smile Re: 2002 Dodge Ram--P1491 fault code
2002 Dodge Ram P1491 Code.
Thanks everyone.
I did find the Condensor Fan Fuse #39 25Amp blown.
I replaced it and the fan works now.
I cleared the code with my $19.95 Autel Maxiscan MS300 code reader.
The Trouble Light on the dash went away.
Trentac is offline   Reply With Quote
Old 04-07-2014, 04:20 PM   #41
Chris Stewart
AF - Advisor
Thanks everyone.
Thanks for sharing!!!
Old 04-12-2016, 10:31 PM   #42
Ram2002Hobbier
I had an instance with the same MIL code. Initially checked the wiring. Did not notice anything unusual. In a web search ran into the AF, all the comments gave me a lot of in depth clues to follow. Checked the relay, it had low resistance. Checked the fuse, it was not blown but the casing was melted up to the PDC bottom. The only thing I did not check was the fan. Following all the ideas suggested here disconnected the battery. I bought a relay and a fuse and replaced them. Then reconnected the battery and took a big sight. I did not know the condition of the fan. I turned the ignition on and looked for any smoke, but Walla! The MIL cleared and the fan started roaring like a big cat. I hope it continues to work thru the summer. After all that I opened the relay and found that the coil was also open. This happened at 83000 miles. I hope this helps you guys. Thanks for all the help you all
Ram2002Hobbier is offline   Reply With Quote
Old 04-12-2016, 10:56 PM   #43
Ram2002Hobbier
Originally Posted by StephenD View Post
I have the same problem, fault code P1491. I found the AC Condenser fan fuse blown. Replaced the fuse. Not blown. Reset the computer. But, the fault keeps coming back. Does anyone have a final resolution for this???
The Following User Says Thank You to Ram2002Hobbier For This Useful Post:
Chris Stewart (04-13-2016)
Old 04-13-2016, 06:54 PM   #44
Chris Stewart
AF - Advisor
Thanks for the useful info!
Old 01-23-2017, 09:00 PM   #45
Pug mike
Hey guys
Just wanted to thanks for all the useful info on this problem
I too simply replaced the fuse as it was indeed blown, cleared the code and my dash is clear again.
Keep on posting
Pug mike is offline   Reply With Quote
The Following User Says Thank You to Pug mike For This Useful Post:
Chris Stewart (01-23-2017)
