| Latest | 0 Rplys |
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
06-20-2004, 07:53 PM | #31 | ||
Re: Re: Sub question
06-21-2004, 07:46 AM | #32 | |
Re: Sub question
Well im thinking about building a 1 cu ft sealed box and then the basket will take up enough space to bring it to what the sub is made for and which ill probably do this weekend
--------------------- 2003 Ford Ranger Edge Supercab Black Bedliner bugshield Chrome bars class3 tow hitch Pioneer 4600mp, Pioneer 6x8 240watt 4way in all 4 doors Rockford Fosgate 501x 1500watt 65x4 Image Dynamics IDQ10 V2D2 sub Walmart crap box (needs replacing SOON) |
06-21-2004, 07:30 PM | #33 | ||
Re: Re: Re: Sub question
if the company lists 1.5-2.0 it will sound better/louder in the 2.0. i didnt' say throw it in a 3.0. if you cant make it at least 1.7 (1.5+ sub displacement)look for a different sub, i believe the one he listed said for 1.5-2.0. you should also figure in port displacement yes the bigger box is better for sq/spl. smaller is better for taking up less space, thats it...they only list smaller sizes because they know that thats whats in. it'll still work just fine, just not as well, and im not making this up, its strait from a few of the subwoofer designers ive talked to. you adjust the port for listening preference. |
06-21-2004, 07:31 PM | #34 | |
you will get quit a bit more from the ported box, but your welcome to try a small sealed box, ive seen it before, and ive fixed it before. most loudpeakers are designed for ported boxes
which sub are you going with? 1st one or 2nd? the first you could do a 1.3cu ft box, ported, and its not much bigger than your planned 1.0. second, id do 1.5 cu ft, still not a whole lot bigger. you already going with a smaller 10" sub, your not going to get a lot of output, use the box to get the most you can from it. if you do decide to go ported, find out what size port, and how deep. make sure the ports on the same side as the driver. if the port was to be 8" deep, the box must be at least 12", if it was to be 6", at least 9" deep (1.5 the port length) a little more space is always better. ports can be sensitive, longer ports tune it lower btw. |
06-21-2004, 11:30 PM | #35 | |
Re: Sub question
Im going with the ID10 V.3 i cant go any bigger because of limited space in the back of my cab (Trucks are musily challenged)
06-22-2004, 12:30 AM | #36 | |
Re: Sub question
Trucks are muscially challenged my A** http://impressivexpressions.com/Memb...oodies/videos/
Mike, you are not completely correct about your larger box better theory. Some subwoofers just perform better in smaller boxes. They are made for it. For example the Elmental subs. A larger box adds a lot more to the low end, but it doesn't really effect the subs high end performance.
www.cloudcity.deviantart.com |
06-22-2004, 08:18 AM | #37 | |
Re: Sub question
Haibane see i cant do that to my bed i use it for loading my quad and hauling stuff so unless you convert you bed to a gaint sub box trucks are musicly challenged since theres no real good place to mount amps and subs
06-22-2004, 10:35 PM | #38 | |
Re: Sub question
yeah, some subs are better for smaller boxes, but in my experience, when a manufacture recomend a range, the bigger in that range is usually better. if all else fails, email the company. ive done this for port tunning. told them the box demensions, and what size port/vent gives what hz. sometimes the companies dont give that info up so easy (just being lazy)
06-22-2004, 11:28 PM | #39 | |
well certain companies need smaller boxes, usually for quality, but like for alpine, the customer service rep told me it just won't sound good... but for kicker the bigger the box is.. usually its better ya know? depends on the sub mostly
08-31-2007, 12:49 AM | #40 | |
Re: Sub question
hey if any one can read this i have a question about building a good size box to house to l7 kicker 12 in square subs. 1500 watt max. i want to build a ported box for them but im not sure on how big to make it. i need the demensions. if you can help please email me at x20dollarsagramx@comcast.com
thanks, Brian |
08-31-2007, 01:47 AM | #41 | ||
Re: Sub question
Seriously, the ONLY subs I woudl go with mentioned above is the RE and ID. Here are a few more to look into. INFINITY PERFECT10d VQ, Elcipse, actually, just Take a look at these links below. http://cgi.ebay.com/RE-AUDIO-SE10-10...QQcmdZViewItem http://cgi.ebay.com/DIAMOND-AUDIO-D6...QQcmdZViewItem http://cgi.ebay.com/Infinity-10-DVC-...QQcmdZViewItem http://cgi.ebay.com/ECLIPSE-SW8000-1...QQcmdZViewItem http://cgi.ebay.com/JL-AUDIO-10W3V3-...QQcmdZViewItem http://cgi.ebay.com/INFINITY-KAPPA-P...QQcmdZViewItem http://cgi.ebay.com/2-New-10-Cerwin-...QQcmdZViewItem http://cgi.ebay.com/2-Image-Dynamics...QQcmdZViewItem http://cgi.ebay.com/NEW-ALPINE-1500-...QQcmdZViewItem |
