Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 10-11-2020, 03:54 PM   #31
wiswind
Re: 2001 windstar
One test that you can do....but only do it for a moment.
I would have a person to start the engine if you want to be outside the vehicle to see.....
Or you can start it, listen for a few seconds and shut it down, without exiting the driver's seat.
Release the serpentine belt........and start the engine for only a couple seconds.
If no noise, it is likely of the many things driven by the serpentine belt.
If you still get the sounds, then it is not one of the things driven by the serpentine belt.
If it is something driven by the serpentine belt......don't forget the 2 idler pulleys, which can become noisy. I have been down that road. I had one that was fine when spun by hand, but load it up and run it, it was a whole different story.
There is 1 pully on the tensioner and one that is mounted to the front of the engine.
It is the bearings that went on mine (both eventually went).
Again, you don't want to run the engine for any length of time with the serpentine belt off as you have no water flow to cool the engine.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
wiswind is offline   Reply With Quote
