| Latest | 0 Rplys |
09-23-2009, 03:26 AM | #286 | |
Re: How many miles do you have your Isuzu?
1994 Honda Passport
3.2L V6 2wd 230xxx miles MAjor Problems: Probably should do an engine rebuilt when i get a second car Recently Replaced: water pump gasket radiator crankshaft timing sprocket crankshaft pulley woodruff key timing belt alternator battery spark plugs wires brakepads all the way around drivers door
1994 honda passport 3.2l v6 2wd |
10-22-2009, 11:57 PM | #287 | |
1996
3.2 SOHC V6 RWD 165,000 Replaced starter 148k Front brake rotors 164k Great truck Best $1500 I ever spent |
10-31-2009, 10:02 AM | #288 | |
99 rodeo keep blowing fuses tail light Why?
12-24-2009, 09:08 AM | #289 | |
98 passport EX 186,000 none of which I put on the truck. I just bought it a few months ago.
Had to replace both front axels, all the ball joints, TPS, EGR, Idle Air Control, 4 O2 sensors, and some other sensor. Also recharged the AC. However the truck is really clean and has been taken care of. No rust or any major body issues. It has great power (just as much as my 99 Taurus w/the 24 valve DOHC). Looks like I'll have to replace the MAF sensor and the Knock Sensor soon. |
12-24-2009, 07:08 PM | #290 | |
My lights kept blowing fuses too. I just put a bigger fuse in and now I have had no problems. But the damn brake pad on the drivers front wheel came off while I was driving the other day and I had to replace all the front brake parts, Rotors, pads, calipers. Pain in the but to deal with. Still the best $1500 I ever spent. Love this truck..
01-02-2010, 10:36 PM | #291 | |
i have a 94 rodeo and it just turned 171000 has been very reliable
01-03-2010, 01:40 PM | #292 | |
1998 LS
3.2L 4WD 162k+ Some pads and shoes,shocks and minor exhaust. Other than that change all filters and keeping the fluid up. Sound truck
98 Rodeo 4wd LS 3.2 153k and Counting |
01-09-2010, 08:34 PM | #293 | |
94 3.2 v6 4x4
bought 4/09 with 150k miles today 1/9/2010 I have 179k Runs great Since I have owned it..... New plugs, wires, 2 coil packs, battery, exhaust, tires, repiars to frame due to rust. |
01-28-2010, 04:47 AM | #294 | |
1994
V6 245,000 Regular maintenance: Timing belt, clutch, brake pads, one set of front rotors, etc. But, problems? Zip, nothin', got no complaints. Has had a valve tick for 175,000 miles that comes and goes. It's my friend now. I'm in the process of replacing ball joints. Bought this demo in '95 with 2000 miles. So, one owner. |
01-28-2010, 09:56 PM | #295 | |
Yearly update:
195K New water pump. High idle currently under control, but I expect it to rear its ugly head anytime. Changed the ISV and TPS a couple times each trying to normalize the idle. Original trans still shifting nicely.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K '96 Jetta 249K '97 TJ 156K '02 VW Cabrio 70K '03 E46 107K |
04-01-2010, 08:55 PM | #296 | |
Year: 1999
Engine: 3.2L V6 M/T Mileage:199,000 Any major problems: Nothing major Mark dingo01@verizon.net Huntington Beach, Ca. |
05-21-2010, 01:55 AM | #297 | |
1999 LS
3.2 2WD Automatic 172,120 not seen the shop HappyMe=A/C.Compressor,Fuel send unit,fuel pump,no oil burn or leaks, still,starts/runs just as it did new.But closed garage kept & proper maint. |
07-16-2010, 12:08 PM | #298 | |
2001 Isuzu Rodeo LS 2WD Auto
Just bought it few days ago with 121k mileage problems: front shocks need to be replaced i can hear whistle from somewhere i need to find it 17mpg |
08-11-2010, 09:36 PM | #299 | |
Year: 1999
Engine:3.2L Mileage:80,200 Any major problems: At 75,000 miles. Replaced A/C clutch. At 79,000 miles fuel sender started reading wrong. Living with it for now. Currently replacing intake manifold gasket and completely rotted through transmission support cross member at 80,200. Rear bumper brackets rusted away. Rear of frame rusted, but not gone yet. |
09-20-2010, 11:24 PM | #300 | |
Isuzu Rodeo S
1998 240,000 Miles and keeps on going and going like the energizer commercial .. love my isuzu rodeo .. |
