| Latest | 0 Rplys |
Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
05-13-2009, 10:41 AM | #16 | ||
Re: Tranny replaced, now it wont start!
05-13-2009, 11:00 AM | #17 | |
ok! when u scanned the computer and got no codes.did u mean it canned and said no codes or did the 2 of them actually communicate with eachother?
05-13-2009, 11:23 AM | #18 | ||
Well the wires being spliced may not be a bad thing. Blazers, Tahoes, S-10's and Suburbans have had issues with the wiring harness and it sounds that someone may have already been in there and replaced the problem. As for what wires to test I'm not sure of the color of the wires but find you a good solid ground and with the key on you should have one wire that is hot from the ingnition switch. BTW is yours the 3 prong plugin or the 4 prong plug in?
In the end there can be only one.........Chevrolet Brad |
05-13-2009, 12:30 PM | #19 | ||
When I scanned it showed zero codes, it communicated normally. |
05-13-2009, 12:35 PM | #20 | |||
On a side note: I called the parts store and they want $367 for a fuel pump, the dealership want $567 |
05-13-2009, 04:21 PM | #21 | |
If you have a carquest nearby they'll sell you one for $300 that's a delphi... Also Advanced auto can order delphi's but most of the counter guys do not know this you have to talk to a manager. I found this out personally when I told a friend of mine I got my pump from carquest and he said there counter guys don't know all the parts they can get, so to prove a point he called his suppler and he could of sold me one for 275 with a discount. Now I no I should go directly to him next time.
2000 S10Blazer LT 4 Door 4x4 Billet Grille insert Winter 30X9.5QR15 BFG's All-Terrain T/A KO's |
05-15-2009, 12:35 PM | #22 | |
Ok,
I checked for voltage at the fuel pump. On the big grey wire I got 12v for a few seconds with the key forward. When the blazer is cranking over its getting 12 volts the whole time. No fuel pressure, can't hear the pump running. Is this case closed.....Bad fuel pump? |
05-15-2009, 01:19 PM | #23 | ||
05-15-2009, 01:24 PM | #24 | ||
05-15-2009, 03:05 PM | #25 | ||
Newbie mod
Getting back to this thread, if you have 12 volts koeo and then 12 volts when turn over the engine, if the ground is good to the pump, like djd99 mentioned, then you have nothing more at that point but the pump. |
05-16-2009, 01:15 AM | #26 | |
Well, I guess this wraps it up. I can't afford to buy a fuel pump right now, I just dropped $600 on the tranny.
I'll push the blazer to the back yard for now and use it for a garden shed. I'll let you guys know how it turns out when the economy picks up and I find a job. My bicycle will get me where I need to go for the time being. Thanks for all the advice. |
05-18-2009, 05:51 PM | #27 | |
Spliced wires prob means the pump was replaced at least once. It's recommended that the plug is changed for a new pump. I don't know why but the replacement plug is diff than the orig. one.
Rich Good |
