| Latest | 0 Rplys |
Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
05-10-2009, 08:54 AM | #16 | |
Registered Offender
Re: AC repair
Those compressors are notorious for leaks at the two case end "O" rings. If you get seven-ten years out of one of the earlier units, consider yourself very fortunate. Reportedly, the newer units (2003-up) have been redesigned to address that leak problem, and the new (not rebuilt) aftermarket units I've installed in the past few years have not come back for leakage. I think they might have wised up and installed quad rings instead of "O" rings in those locations, but I'm not sure.
It won't hurt to replace the components, drive it for a while with the AC clutch wire disconnected (it shouldn't run with no refrigerant charge anyway, but it's a sure thing if the clutch is disconnected), then evacuate and charge it later. Oil is critical, and you need to add the correct volume of PAG when installing the compressor, then manually turn the compressor to distribute the oil and clear the cylinders. Definitely replace the orifice tube/screen unit and at the very least, remove and clean the accumulator, or just replace it.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
05-10-2009, 09:01 AM | #17 | ||
AF - Advisor
Re: AC repair
Best to pump down and recharge as soon as you can after installing a new reciever/dryer. After the sealing caps are removed from a dryer they tend to start drawing moisture. That is one reason for a good vacuum pump down. As Blue Bowtie says the correct amount and correct oil is very importain. That is where a fush comes into play. After a fush it is easy to get the correct amount of oil in it. Good Luck
05-10-2009, 04:25 PM | #18 | |||
Re: AC repair
05-16-2009, 09:10 PM | #19 | |
Re: AC repair
I am preparing to replace the parts on my AC, but had a question specific to the S10. Does anyone know exactly where the orifice tube is located? There don't appear to be any obvious places.
Also what kind of CFM's are needed for good evacuation? I see lots of air operated pumps, but the CFM's are in the 4 range. Don't know if this is enough. Thanks for your help once again. |
05-17-2009, 10:31 AM | #20 | |
Re: AC repair
OT is in evaporator inlet-at bottom of Evap- have to remove accumulator to properly access-
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
05-18-2009, 12:01 PM | #21 | |
Re: AC repair
Thanks, br
That's no problem. I'm replacing the accumulator as part of the package. Do you know what "good" pressures should be on the low and high sides? Also, my accumulator is on the low side. Isn't the accumulator usually on the high side? |
05-18-2009, 01:21 PM | #22 | |
AF - Advisor
Re: AC repair
Good low side is around 28-32 lbs.
Remember evaporater out let tempt is close to low side tempt. 30 lbs = 30 degrees = cooling. High side depends a lot on engine cooling and outside tempt. 150-250 is good high side range. Good Luck
