| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
#16 | ||
Re: Structural Rigidity enhancement...
The reason why is because I fear the car has been damaged/weakend due to an accident six months ago which swayed the nose. the Rx7 is a very "flimsey" car persay. It has one of the best suspensions (Double wishbone) but the frame is very flexible an flexes very easily. I don't have very many tools at my disposal so when I need to do routine stuff I do it the "ghetto" way persay. I did an oil change once by pulling half the car up on a high curb an draining the oil out like that. When I opened the doors and an trunk to get somestuff an it was on an angle I couldn't close the trunk nor the hood or even the drivers side door! That is very serious flex to me.
#17 | |
Razor Sharp Twit
![]() Join Date: Mar 2004
ok.... so in short, you have wrecked your car then.
if there is that much flex to begin with, injecting expanding foam into the frame might not be the best thing to do and won;t actually do any good if the frame is already compromised. By the way, if simply putting the car on a curb causes body flex, then I'd say that something is/was wrong with your car. The RX-7 shouldn't be like that. From what I recall, the car is meant to be very stiff structurally but on softer springs/dampers; very much like the MX-5 and RX-8 and that is what makes it so progressive.
AF's Guidelines Read them. __________________ ![]() Currently in the process of re-hosting my photos. If any go missing, drop me a PM. |
#18 | ||
If you don't believe me, then I suggest you do some experiments with the foam first. Fill up something like a balloon with it, let it harden and see how stiff/strong it is. It'll be about 3 times stronger than a dry kitchen sponge.. Human bone does not compare to steel for strength. Neither does urethane foam. Carbon fibre is not related to this discussion at all. But carbon fibres are exceptionally stiff, stiffer than steel. |
#19 | |||||
#20 | ||||
(Apex'i Kyoto Hakubai BNR32 GT-R) ![]()
#21 | |
Professional Ninja Killer
![]() Join Date: Nov 2002
All cars flex, its just a matter of how much.
The foam has been shown in many applications to do wonders. Driveshafts that were installed behind Duramax diesels hold up to well over 1000 lb-ft in part because the thin-wall aluminum shaft is injected with urethane foam. Have you guys ever used a can of that expanding foam? You know what its like after it hardens? Well the urethane foam is like that times ten. It is VERY effective at helping. How much depends on several factors, but I don't doubt that its an effective means of helping rigidity. I know it seems illogical given its light weight, but seriously, its like adding epoxy to fiberglass. Neither one is very strong alone, but put them together and they are very strong. The foam gets its strength from the billions of geometric shapes formed in the bubbles.
Dragging people kicking and screaming into the enlightenment. |
#22 | |
then it seems to me that the reason for the stiffness isnt the foam at all, but the fact that it expands.
it is no mystery that when you put an object under tension it is stronger. this science was recently used in golf clubs and yeilded huge gains in drive length. not to say that golf clubs compare to a frame of an rx-7, but the general idea is the same. preload the frame with a certian ammount of tension and it will be stronger. how much stronger, i cannot say, but it could help some. personally, i'd check that frame again. if it contorts by simply putting it at an angle by driving it onto a curb, then you are starting way behind. how hard would it be to find a doner car with the stiffer frame and swap in all your parts? it would certainly be more cost effective than trying to stiffen a frame that is weak to begin with. kind of like turboing your grandmothers buick. it will help. thats obvious. its just a bad platform for a build. thats just my opinion |
#23 | ||||
She's a real gem if you see her in real life ![]()
#24 | ||
Just because you see something done on a video, doesn't mean it's safe or even works. I'd hate to see someone hurt or even killed because they think some plastic foam can make their car stronger than a roll cage will. |
#25 | |||||
There's always people who doubt that thing's "cannot be done" or "won't work" but ever since the invention of the 3 and now 4 rotor I come to think any thing is worth a shot.
#26 | |
You guys are missing the point of the foam. Its not pressure, ITS THE FOAM ITSELF. Try it sometime with just the cheap can of spray foam in a piece of exhaust tubing, then span it across a couple boards and stand on it. Compare it to a non-foamed tube and you'll see.
Think of it this way. Lets say you got inside the tube and welded in about 10 braces across the tube at random angles. It would strengthen it, right? Now, think about doing that with hundreds of billions of hard hair-strands of polymer. Its the same thing. You're taking a bubble of polymer (not very strong) and multiplying it billions of times in geometric shapes. Its strong stuff.
#27 | |
is it similar to "great stuff"
i've got a can or two of that laying around... |
#28 | |
Razor Sharp Twit
i'm aware that foaming the chassis works.
my point is, I'm not entirely sure if parking your car on a curb should be causing that much longitudinal flex in the chassis to a point where the doors or boot can't shut. If there is a weakness there, filling it with foam might give you temperary strength but the frame is still gong to be compromised. What kind of scan did your car have? when he said that there is strength gained from internal pressure, he is talking about the pressure caused by the foam wanting to expand and the frame not letting it. This is also what I was talking about when I said it would put extra stress on the joints of the frame. Why do you want a stiffer ride?
#29 | |
my biggest argument is that if the foam cracks, you will be left with an unevenly stiff chassis.
you compared it to bone, and bone cracks pretty easily. i guess i have to try the "great stuff" experiment. |
#30 | |
That thing got a Hemi?
i doubt an aerosol of this foam will deliver the kind of rigidity you expect, if there is such a gain to be had, as shown by this GT-R i'd imagine they used some gear a little more "heavy-duty" than squirting a can of foam into the frame's hollows.
Seatbelts Saved My Life ![]() |
