| Latest | 0 Rplys |
02-25-2004, 12:39 PM | #16 | ||
Re: Re: Re: Codes 171 & 174 too lean
Here's an even better write-up and solution to the oil problem, it's for the mustang but it is the same problem: http://www.miracerros.com/mustang/pcv_filter.htm The only problem is that our PCV hose is horizontal instead of vertical to allow the oil to drain back into the valve cover. But there is enough room under the hood to reroute it to provide for this setup. I know others have tried an in-line filter with limited success but I think the key is to get it installed vertically so the oil can drain back via the PCV valve. |
02-26-2004, 09:48 AM | #17 | |
Well I did the TSB last night. Took me about 3 hours. Not that hard. The mechanic at Ford gave me a print out of the exact step by step procedure for installing new bolts and seals. Which was nice. I had allot of carbon in the ERG vavles, and there was allot of oil. Van runs allot better and with more pickup. The egine light is off, guess we will see if it stay off.
02-26-2004, 09:53 AM | #18 | |
Hey Lewis, I went to that site you posted on the valve. I think his in-line fuel filter ideal is allot cheaper than replacing valve cover. Think this would be a good idea?
02-26-2004, 11:19 AM | #19 | ||
Also the frustrating part of the TSB is that you are working on the effect of the problem but never the cause. So the new bolts will keep you from getting a leak in the future, but you will still have the oil problems eventually leading to clogged EGR ports and excessive carbon deposits leading to pinging. This simple fix might be a way to eliminate the cause of the problem. |
02-26-2004, 01:06 PM | #20 | |
Why does is have to vertical, mine runs horizontal no way for me to mount vertical.
02-26-2004, 01:31 PM | #21 | ||
02-26-2004, 02:54 PM | #22 | ||
02-26-2004, 02:56 PM | #23 | |
Im just going to bit the bullet and get the new valve cover. I think it may help in the long run. The only thing that would be left is the PCM upgrade. I dont really think its needed, anybody else have any opinions on it?
02-26-2004, 02:59 PM | #24 | |
By the way, if anyone out there does the owrk themselves, I recommend going to Ford and have them print out the procedure, it made it allot easier. I have it printed out and can try to fax to you guys if you think you need it. You can send me your fax number to ufrules@hotmail.com if you dont want to post. Ford may not give to everyone, I had a really nice tech print out for me at Ford even though he said he not suppose to.
02-27-2004, 10:11 AM | #25 | ||
02-27-2004, 12:42 PM | #26 | ||
02-27-2004, 12:44 PM | #27 | |
I just install new Valve cover. Looks like the only difference between the old and new is the small hole they talked out in the TSB that is positioned at 5 oclock under the PCV valve. Wonder if there is a way to cover the hole without replacing the entire valve cover. Too late for me but maybe someone else can figure out.
02-27-2004, 12:53 PM | #28 | ||
Re: Re: Re: Re: Codes 171 & 174 too lean
02-27-2004, 01:18 PM | #29 | ||
Re: Re: Re: Re: Re: Codes 171 & 174 too lean
02-27-2004, 01:23 PM | #30 | ||
