Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-29-2014, 11:46 AM   #16
rons52
Re: Driver side power window not working
Is the green wire supposed to be hot at switch when ignition key is on.
rons52 is offline   Reply With Quote
Old 01-29-2014, 05:50 PM   #17
j cAT
with the key on power should be at the control switch.
the motors on these fail often. see if you have 12 volts across the motor with the window switch on
j cAT is offline   Reply With Quote
Old 01-29-2014, 06:19 PM   #18
rons52
I know the motor is good. I just need to find out if green wire is always hot or just when key is on. Or if it is hot at all. Thanks for your time.
Old 01-29-2014, 06:28 PM   #19
j cAT
explain what you know and why ? is there power at the driver side master control switch ?
do the other windows work with this switch ? what is the problem exactly ?
being a newbie to these forums the proper method is to make your own posting with your issues and your complete vehicle details including testing and results completed if any.
Old 08-16-2017, 10:00 PM   #20
CSavage
Wink Re: Driver side power window not working
I had the same issue on a 2002 Yukon XL.
Traced back the dark green wire to the fuse box, spliced in a new wire at the fuse box and ran it to the switch, problem solved.
Thanks for the post.
CSavage is offline   Reply With Quote
Driver Side Power Window Not Working - 99 GMC Jimmy 99gmcjimmy Problem Diagnosis 13 02-29-2012 09:13 AM
2000 blazer Driver side power window not working David426 Problem Diagnosis 2 02-21-2007 12:53 PM
Driver Side Power Window stopped working jcassandra00 Grand AM 2 12-22-2005 06:29 PM
driver-side power windows don't work on 94 blazer tahoe jchohio Blazer 3 04-13-2005 07:06 PM
driver's side power window not working umrmeche Blazer 9 10-02-2004 10:49 PM
Tags
power , window
