| Latest | 0 Rplys |
08-17-2012, 06:21 PM | #16 | |
Re: Rough Idle Only When In Gear
IAC issues go hand in hand with throttle body issues ... make sure the throttle body and plate are clean and everything around lubricated ... WD40 or the like.
10-12-2015, 07:35 AM | #17 | |
Greetings to All!
This is my very first post in this forum. I have heard many good things about this particular forum and the folks that inhabit it! I have a 2002 Windstar SE that has this identical issue of idling rough while in gear, but not in Park or Neutral. Now she keeps throwing a TC that indicates a wee air leak in the intake manifold. As I am on a pension, I have demurred on that repair until it becomes an absolute necessity. I have had two professional mechanics check her out for vacuum leaks as have I, but none of us could identify one! (which came as a bit of a surprise, really). Cleaning the idle air control valve is a new idea for me, so I will plan on doing that today or Tuesday, depending on how busy I am today. Is there anything else in the realm of regular maintenance that I want to pay special attention to? Yes, the air filter has been replaced in the last month! LOL |
10-12-2015, 09:00 AM | #18 | |
Can you post the P-codes you get from the scanner? The specific codes are vital to helping track down the problem.
The Following User Says Thank You to scubacat For This Useful Post: |
LordDarkStar (10-13-2015)
10-12-2015, 11:29 AM | #19 | |
Thank you for your reply scubacat. Unfortunately, I cannot provide any P codes related to this issue at present. I am unable to find my notes that lists the singular code that was thrown. I have a friend who is a master mechanic coming over this weekend to help me with my van and I'm certain he will have his diagnostic computer with him.
However, I did forget to mention one possibly significant fact that makes the issue I am having different from the issue described by the original poster and that is the rough idling issue is present whether the engine is cold or at normal operating temperature. I will update this thread with the P code and the results of cleaning the Idle Air Control Valve as soon as I possibly can. |
10-12-2015, 12:10 PM | #20 | |
Ok. If it is, in fact, a lean code, check the P0171/P0174 sticky thread. That's a well known issue with the lower plenum bolt grommets and a fairly easy and very cheap fix. If there's a misfire, check that, the EGR ports, and the coil pack for cracks. Those are the 3 usual suspects.
10-12-2015, 02:27 PM | #21 | |
It would be helpful if you'd post the type of engine (3.0 or 3.8 L) as well as the mileage on the engine.
There are a number of root causes for rough idle while in gear. Some are relatively simple, others take a little more teardown & repair. First, lean operation due to a vacuum leak doesn't necessarily mean misfire (rough). The computer can compensate for significant excessive air entering the intake without leading to misfire. It is helpful to check for oil in the throttle body and plenum (boot between the throttle body and the air filter). This oil is a sure sign of blow-by (due to worn rings). The extra oil might be enough to give a lean reading due to unmetered "fuel" entering the engine (since the oil burns). Similarly lean codes can be the result of a malfunctioning fuel injector if it releases too much fuel. I've had misfire issues that were related to the EGR system as well. When the EGR are ports are clogged you can get misfire under light acceleration. An EGR that sticks open might cause issues at idle. Another source of misfire can be the Idle Air Control Motor located on the intake near the throttle body. If the IACM is malfunctioning then the computer can't optimally adjust the intake air flow at idle. |
The Following User Says Thank You to tomj76 For This Useful Post: |
10-13-2015, 10:32 AM | #22 | |
Thanks some more scubacat and thanks for weighing in tomj. She has the 3.8L engine with approximately 141K miles on her. In thinking about the specific trouble code thrown, although I still am unable to find my notes, I would swear an oath that I was told it was due to running lean. Therefore, I will be checking out the sticky topic that you recommended scubacat. While she does idle roughly, I don't believe there's a misfire involved. I have experienced misfires in a previous Windstar that I owned and they are significantly more violent than what I would describe as a significant vibration that I am experiencing presently with this Windstar. Also Tom, when I replaced the air filter for her earlier this summer, I did closely inspect the insides of all the different components that I had to disassemble to get the filter out and back in again. Despite her high mileage, I am pleased to be able to report that I found no sign of oil, either visually or by feel anywhere along the exposed air intake pathway. I will be checking out the EGR valve the next chance I get.
I did get around to cleaning the idle air control valve yesterday. There was some soot present inside the valve and it was cleaned out as thoroughly as I possibly could. The spring is intact and the valve inside the housing moves quite freely. However, I did not notice any appreciable change in engine performance when I drove her last evening. It was only a short distance, so perhaps I'll notice some difference while out and about today. Thanks again for all of your excellent suggestions! I'll continue to update the information as I uncover it. |
10-15-2015, 11:45 AM | #23 | |
Is the check engine light (MIL) on? Don't overlook AutoZone's free code reading service.
It is good to know that you don't have oil in the intake, even at 141k. My experience with the EGR issue is that the system can be clogged. My first experience with clogging was at the EGR "ports" which are located in the lower intake manifold. There is one for each cylinder. They are accessible by removing the upper intake manifold (plastic piece) and can be cleaned with a combination of solvent and mechanical removal (I've used a drill bit and a wire brush). I use a vacuum to suck and removed material from work area before it can fall into the intake. It's a fairly common operation that is frequently discussed on this forum. The second EGR clogging experience was in the EGR pipe between the exhaust manifold and the EGR valve. The EGR pipe has two small tubes that are located on ether side of an internal orifice. The tubes and orifice allow the DPFE to sense the amount of exhaust gas that is flowing back to the intake. I was able to remove Soot clogging the small tubes with a small piece of music wire and heat (applied to the tubes) to "cook" it. It think I tried solvents as well, but the heat was required to burn out the clog. This clog was indicated by a stored trouble code indicating a malfunctioning DPFE. Don't overlook the ignition system. Make sure all the plugs and wires are in good condition. Some old fashioned vacuum gage analysis might be of help as well. |
LordDarkStar (10-15-2015)
10-15-2015, 12:46 PM | #24 | |
Thanks for the follow-on about the EGR, tomj.
I happened to Stop at my neighborhood O'Riley's Auto Parts today and had them check the P codes. Sure enough, the codes came back as P171 and P174! So now at least my course is clear. It'll have to wait until at least next month as money is extremely limited for the rest of October and there are any number of PM's I intend to perform while I have the Windstar's cowling removed, not the least of which is replacing the wiring harness and plugs, cleaning/replacing the EGR and dealing with that other component that seems to like to take a dump once the P171/174 issue is resolved. Just hope the weather stays fair until the work is completed!
Non illigitamus carborundum! |
10-16-2015, 05:34 PM | #25 | |
Hey Guys! Been studying the sticky 'bout fixing the problem for the P codes 171 & 174. REALLY like the link to the webpage (http://leckemby.net/windstar/windstar01.html) and the fact that he covers the P code 0401 as well since it seems to regularly follow fixing P171&174. I do have a couple of questions that I'm hoping you can help me with. First: Rather than replacing the valve cover on my engine if it indeed has the notorious hole in it, could I just clean it up thoroughly and patch the hole with some J.B.Weld or the like? Second: Could someone please tell me what the acronym DPEE stands for? I just cannot figure it out! Thanks all!
10-16-2015, 06:00 PM | #26 | |
Not sure on the valve cover. It's a design issue; the hole is just how you identify it. I'd replace it. I believe you can get an after-market part for not too much (or a junkyard part from a newer model that has the updated cover).
DPFE = Delta or Differential - Pressure - Feedback - of EGR. It's just a fancier term for "EGR Sensor". Surely somebody concocted it in a Ford corporate-level meeting to score brownie points. Anyway, the DPFE sensor is what fails and can trigger an EGR code. Clean the ports in the manifold when you have the cover off and replace that sensor, but do NOT waste money on an EGR valve. They almost never fail. The code(s) can be misleading and tempt you to replace that valve, but you'd likely be throwing money away doing so. The DPFE sensor is usually around $20 and takes one minute to replace. You also do not have to replace the plenum bolts, so no need to fork over the ransom for those from a dealer. You can just cut off the grommets and get another set for about $8 from rock auto; the silicon upper plenum gaskets ("port seals") are just a few bucks as well; replace them too. Even if you already have the green grommets, that is where your vacuum leak is occurring, so just replace them again. The green ones are improved, but nothing is foolproof. And, they're cheap anyway. Two other things to check when you have the plenum off: First, the little white "IMRC" bushings. They'll be on the little metal actuator arms on the left side as you're facing the engine compartment. It's $5 for a 5 pack from an auto parts store (a dorman part). Once again, don't get gouged by the dealer for those. Even if they LOOK ok, they may be on the brink of disintegration like mine were. Do yourself a favor and replace them when you have easy access. Second, the water bypass tube you'll see attached with 2 bolts across the metal intake manifold. It will eventually leak at the 90-degree bend. It's about $32 for a new one from rock auto and $70 from a dealer. I replaced mine (for $32) preventatively. You can skip this, but you may be removing everything again someday if that springs a leak. Just something to keep in mind. Good luck! |
LordDarkStar (10-16-2015)
10-16-2015, 09:08 PM | #27 | |
Flat out AWESOME info, scubacat! You can count on me using every bit of it too! Thanks SO much!
10-17-2015, 10:55 AM | #28 | ||
