| Latest | 0 Rplys |
Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
#16 | |
Re: 93 S10 blazer 4X4 probs
iv checked and cleaned connectors at tccm and transfer case prolly 8 times sometimes it will work for a day or 2 then its back to doing the samething i was thinking of checking the wires to make sure theres not a short somewhere but i dout it whn i check tccm error codes it says it the shifter motor ill change the vac switch on trans case and check fluids again...ill gets pics when i check connections again and post them thx for all your help
#17 | |
Advisor/Moderator
![]() Join Date: Nov 2005
82Stang, are you looking for a wiring diagram, (schematic)?
slp4days, Could be a poor connection that gets moved when you take things apart. I've seen poor crimp connections where it missed the stripped wire and hit insulation along with it during the crimping process.
You have to know how it works, to figure out why it doesn't. Last edited by old_master; 03-06-2012 at 06:14 PM. |
#18 | |
Thanks OM, but that's not necessary. I do appreciate you asking though. This is my rarely used plow truck, almost all the way out to pasture. It is on very light duty from now on. It def doesn't look pretty, but 192K and still going.
"When I was a kid my parents moved a lot, but I always found them." Rodney Dangerfield |
