Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-05-2011, 01:08 PM   #16
Maulana
Send a message via Yahoo to Maulana
Re: 96 Cam LE new front struts-wheels pulling hard, both directions
Went back to shop and asked mechanic to go out to test drive with me so he could hear noises from wheel. When it happened I asked him if he heard it. He replied his hearing aid was not working right. It gets worse, but long story short--he admitted to nothing but offered me my money back (the labor) telling me to take my problem somewhere else.
Went to another shop, mechanic identified scraping metal sounds as thin metal plate that protects brake parts from dust and debris being bent and out of place (he corrected).
This mechanic suggested that the other mechanic had broken the bearing of new mount while installing, probably by over-tightening and that's why he would put one of the old bearings back into the new mount. He said old bearings is why you replace the mount in the first place.
So at best, I have to buy at least one more mount and have it installed again (and trust that first mechanic gave accurate info as to what he did and which side the new mount with old bearing is on), and do another alignment.
Maulana is offline   Reply With Quote
The Following User Says Thank You to Maulana For This Useful Post:
Brian R. (08-05-2011)
Old 08-05-2011, 01:12 PM   #17
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Sounds about right. I would cut my looses and get what money I can from the first mechanic. You should be able to easily tell which side is correct and which side is not. Get someone to double check (if you can't) which mount is needed before you buy a new mount.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
The Following User Says Thank You to Brian R. For This Useful Post:
Maulana (08-09-2011)
Old 08-05-2011, 01:50 PM   #18
inafogg
good to hear you got your labor money back.the parts house may replace the parts under warranty(its not a big deal for them to do so)even if its not a parts failure.
i might want to replace both l/r mounts just to be sure,unless new tech does'nt rec.
then you just have to pay for an alignment again.
you may want to look at an exploded view of the mount,bearing,spacers,washer,to be sure you have all the pieces
Good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
inafogg is offline   Reply With Quote
The Following User Says Thank You to inafogg For This Useful Post:
Noise from front when going over bumps paraip Element 2 08-28-2012 02:25 AM
Steering wheel shakes after new struts Oopey Camry/Camry Hybrid/Vista 2 08-03-2009 01:00 PM
Got the new front struts on the 01' PA TopherS Park Avenue 3 03-02-2008 02:16 AM
problem with new front struts madmaxatv Grand Prix 11 03-03-2006 10:52 PM
1993 camry front left wheel pulls when cornering hip2hop Camry/Camry Hybrid/Vista 5 01-13-2006 12:50 AM
Tags
camry , pulling , steering , struts , wheels
