| Latest | 0 Rplys |
#16 | |
Re: Overheat
do you have axcess to a pressure tester?
try pulling a coolant hose off(easiest 1)to see what it looks like can you see anything in the radiator or just on the cap that maybe dexcool that your seeing on cap?hard to tell from here let us know
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
#17 | |
i'M THINKING YOU MAY BE RIGHT! I was reading up on another thread moments ago that the sludge is dexcool from air getting into the anti-freeze?
#18 | |||
Re: Overheat
Not according to the photo you posted. Did you drain coolant out of the radiator before taking the photo?
When was the last time the cooling system was flushed and the coolant replaced with fresh stuff? First Guess: Plain ol' ordinary neglect. Use infra-red temperature "gun" to verify no cold spots on radiator when engine is running, fully warmed up, and the fans are NOT running. Flush coolant THOROUGHLY, open radiator and block drains to remove flush water. Inspect radiator for clogging/corrosion. Inspect hoses for deterioration. Clean crap out of overflow bottle. Install the coolant brand/type of your choice, in aproximately 50/50 mix with water. Replace rad cap--I like the lever-lock style for safety. See if the ugly stuff in the radiator comes back.
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
#19 | ||
Re: Overheat
I will flush it out tomorrow and see what happens |
#20 | |
Re: Overheat
I'm flushing my system, after 5 min looks like it's gonna overheat then fans kick in and needle starts going down. I look u8nder the hood and notice no water is going into my top hose. Hose looks like air being squeezed out... I turn off the car and hose goes back to normal.
I'm assuming my thermostat isn't opening up? |
#21 | ||
Re: Overheat
#22 | ||
Re: Overheat
if you were adding/mixing regular antifreeze to a factory dexcool system it will sludge up the entire cooling system!!! the entire system including overflow must be drained & flushed good, probably a few times until everything is cleaned.best to remove the thermostat while flushing replace all hoses if possible along with cap & thermostat Good luck mike
The Following User Says Thank You to inafogg For This Useful Post: |
bsr2002 (04-18-2011)
#23 | ||
Re: Overheat
#24 | |
Re: Overheat
This is the stuff I been using to top off my coolant...
#25 | ||
Re: Overheat
Tricia, GM Customer Service. |
