Go Back   Automotive Forums .com Car Chat > Car Audio
Old 04-06-2011, 09:04 AM   #16
xxCarmaxx
Re: MTX Terminator Amp Issue
Okay, so I've narrowed down the problem. If I turn the stereo on without the RCA's plugged in, it does not go into protect. Then I simply plug the RCA's in and proceed to play music, but if I turn the stereo on WITH the RCA's plugged in, it goes into protect.
xxCarmaxx is offline   Reply With Quote
Old 04-06-2011, 02:35 PM   #17
PaulD
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I am assuming this an aftermarket cd player, I saw no mention of a LOC being used. First off, do NOT diconnect or reconnect the RCA's while the stereo is operational. Where is the cd player grouned, where is the black with connected ?
PaulD is offline   Reply With Quote
Old 04-06-2011, 03:05 PM   #18
xxCarmaxx
Uh Oh I've been doing that, how bad is it for the amp? Also, the stereo is ground]ed via the wire harness if I'm not mistaken
Old 04-06-2011, 06:48 PM   #19
PaulD
Audio Guy
ok for the amp, the inputs are normally protected - bad for the headunit. If you have a Pioneer headunit you have assuredly blown the pico fuse already.
Remove the headunits ground wire from the harness connection and attach it directly to a bolt behind the dash, that's why it had a metal lug on it that you most likely cut off to attach it to the harness. Those harness grounds are usually poor for an aftermarket headunit. It may be causing your voltage problems.
Sub, mabye amp issue skylakaylah Car Audio 2 01-04-2010 05:45 PM
Amp issues. jtvyper456 Car Audio 4 01-06-2007 01:57 PM
4 channel amp issues muskilunge Car Audio 18 08-17-2006 06:43 AM
Amp issues... partyaw Car Audio 3 08-10-2005 07:30 AM
Sub/amp issue.. they stopped working 90gs Car Audio 2 08-04-2003 04:55 PM
