Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 07-26-2011, 09:45 AM   #16
Schurkey
Re: 95 3.1 dies intrmtntly, restarts for sec, dies
Originally Posted by 95lumina340 View Post
there are two systems that tell the fuel pump to give fuel: one for when the car is starting, one for when the car is running.
GM vehicles run the pump for two seconds when the key is turned on. Then the fuel pump is turned on again when the ECM discovers that the engine is cranking/running.
the car would start and then die right away. so my mechanic friend connected this pigtail to the positive terminal and then the car would stay running (!!!).
You've just figured out that the ECM is not tripping the fuel pump relay when the engine cranks. (or the relay or relay wires/fuse are defective.)
if you connect this, put a kill switch and fuse or something cause it will keep the pump running 24/7 and drain your battery.
That's crazy. Fix the true problem instead of using the fuel pump test wire to run the vehicle.
i looked on someone's 99 and didn't see this pigtail, so it may not be there on all years.
I haven't seen the test connector on my '92 and '93 either, although it may be there somewhere.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Schurkey is offline   Reply With Quote
1991 Cutless supreme 3.1 stalling mandude Cutlass Series 9 02-06-2015 01:16 AM
knocking after oil change 3.1 moemo Cutlass Series 1 10-20-2010 07:37 PM
2002 3.1 thermostat removal DigduG1975 Grand Prix 1 05-29-2010 09:47 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 09:55 AM
3.1 interchange info please. Ponyak Grand Prix 2 06-08-2009 11:58 AM
