Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 11-30-2008, 11:35 PM   #16
Morley
Re: 305 TBI Camaro won't start unless primed
Originally Posted by kutison
Remember that the pump is not working, I have it wired through an accessory line
You completely rewired it? The easiest and simplest way to get the pump to run is to apply +12VDC to ALDL pin G, it will power the pump. I thought you had just jumpered across the relay.
Morley is offline   Reply With Quote
Old 12-01-2008, 11:57 AM   #17
wrightz28
is bring'n sexy back
wrightz28's Avatar
Don't you love when the 'little details' are left out?
I'll bet the farm now it's the fuse.
wrightz28 is offline   Reply With Quote
Old 02-22-2009, 06:10 PM   #18
kutison
Originally Posted by wrightz28 View Post
Don't forget the ECM fuse by the battery, it's a 20A inline.
And the winner is....wrightz28 It was the blown ECM fuse by the battery. I couldn't find that thing, until someone pointed it out for me.
Thanks for your help
kutison is offline   Reply With Quote
Old 02-23-2009, 09:12 AM   #19
wrightz28
wrightz28's Avatar
Sweet, thanks for the update.
Old 08-14-2014, 05:54 PM   #20
jenniferc903
My car is doing the same thing. HELP!
jenniferc903 is offline   Reply With Quote
Old 08-14-2014, 08:55 PM   #21
Tech II
Year, make, model, engine, and transmission?
Does the car crank over and not start, or not crank over at all?
If it cranks and doesn't start, check for spark, fuel pressure , and injector pulse......if you have TBI, does fuel come out of the injector(s) while cranking the vehicle?
Scanned for codes?
Tech II is offline   Reply With Quote
Old 02-11-2016, 10:52 AM   #22
impalafunk
I have a 1964 impala that I swapped out the drive train out of a 1992 1500 chevy truck. so I have the 350 with tbi and 700r4 trans. my problem is that it will not start unless primed but once I prime it it runs perfect. I can drive it around fine and it idles fine but once I turn it off it will not start. cranks fastbut no start. I can hear the pump going and when it starts cranking I can hear the pump stop. but it starts pumping agin while the car is running. so far ive replaced the fuel filter and completely rebuilt the throttle body.. while the body deff did need rebuild it still doing the same thing. is there something that is supposed to splash fuel into the body when start??? help a rider out please
impalafunk is offline   Reply With Quote
Old 02-11-2016, 10:54 AM   #23
impalafunk
one more note,,, this is not a new build. ive had this car running for 5 years so the problem is new. car has allways started good...
Old 02-11-2016, 11:23 AM   #24
maxwedge
A990 racer
When cranking do you see fuel spraying from the injectors?
maxwedge is offline   Reply With Quote
Old 02-11-2016, 11:34 AM   #25
impalafunk
I will look today when I get home. haven't had anybody to crank if for me while I look but I will make my son do it. I don't think it is tho b/c if it was I think it would start sence when I put a little in it starts right up. what would cause it to not spary while cranking? it sprays fine while running. i can hear the pump run when i turn key to on position but once i bump it to start , the pump stops , but if once car starts pump can be heard agin.. while the pump is running but the car is not no fuel can be seen at the throttle body
Old 02-11-2016, 01:54 PM   #26
impalafunk
does anybody no what would cause the injectors to not spray when the engine is cranking but spray once started with the help of priming???
Old 05-24-2016, 04:27 PM   #27
Sodell9539
I run into this problem all the time. There seems to be electrical issues in the steering column. You can check the ignition issues by bypassing it with a push button start. It should start when you do this.
Sodell9539 is offline   Reply With Quote
