Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 08-17-2011, 10:28 PM   #16
olopezm
olopezm's Avatar
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: need help with fuse 20 in power dist box, details below
I'm glad you fixed your problem. Thanks for letting the forum know what was the cause of it.
For future reference
Disconnecting the battery while the engine is running used to be a good measure for older vehicles but with all the electronics involved in PCM controlled vehicles it's a DEFINITELY BAD IDEA.
Why is that?
Because the load on the system is being sensed to properly adjust the voltage regulator duty cycle in order to provide the optimal/correct amount of current form the alternator. If you disconnect the battery the system will sense a huge load (open circuit/high impedance condition) and will activate the regulator at 100% duty cycle, since the current has to go somewhere, all of the electric/electronic circuits will be affected (mostly toasted) because of the high current being fed.
Regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
olopezm is offline   Reply With Quote
Nursing student needs help with fuse prob. jdepew Stratus 6 10-01-2006 05:22 PM
89 Cadi Deville, need help with fuses I think 89DUBDEVILLE Deville 0 03-20-2006 02:35 PM
need help with fuses in camaro rsgirl92 Camaro Discussions 19 01-13-2006 12:22 PM
need help with fuses have fuses gone liltutt75720 Crown Victoria 5 12-12-2005 01:11 AM
Need help with fuses! cauc_aZn '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 06-04-2002 08:28 AM
Tags
2002 , maf , schematic , windstar
