| Latest | 0 Rplys |
12-15-2007, 01:28 PM | #16 | |
Re: 1969 Cougar
Sounds Like Its Going To Be A Strong Running Cougar, Came In Late On Your Swap, But Woth The Tranny, Sounds Like A Newer Mustang Instead Of Vintage That You Sold. I Have A 69 Coupe (not A Fastback-darn) Anyway, Have Been Trying To Find A Headliner Rod For So I Can Get The Headliner Put In, I Need The Sencond From The Front, Not Sure If All Are Different Sizes But I Know There Are At Least 2 Different Sizes, Makes A Difference, If You Have Any Ideas Are Know Anyone Who Might Have One, Sure Would Help. Thanks For Any Help. Good Luck With The Cougar, Looks Good.
12-16-2007, 07:03 PM | #17 | |
Re: 1969 Cougar
Late Model Restoration Supply might have them.
1969 Cougar 357w & TKO - 475hp |
12-16-2007, 07:06 PM | #18 | |
Re: 1969 Cougar
Update:
450-475hp - 357w/TKO installed. MSD installed. Shortened driveshaft installed. Long tube Flowtech 1 1/2" X 3" headers installed. Going back in the morning to top the tranny off with fluid & turn the key. Wish me luck!
12-17-2007, 11:20 PM | #19 | ||
Re: 1969 Cougar
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
12-18-2007, 12:16 AM | #20 | |
Re: 1969 Cougar
Yes yes Tony. Pics are coming soon. It fired right up today, going back in the morning for one last clutch adjustment and then I'm driving that cat home. I'll snap some pics for you tomarrow. I had the camera today but was just too busy double and triple checking everything to think about taking pics.
12-18-2007, 11:02 AM | #21 | |
Re: 1969 Cougar
Great news!
Was the TKO a pain? I am thinking of going T5WC for my Cougar.
12-18-2007, 02:36 PM | #22 | |
Re: 1969 Cougar
Well I fabbed my own stuff instead of spending hundreds on "swap parts". It was not much worse than any manual tranny install though. Dont be alarmed if your shifter is off the the pass side of the shifter hole though, I had to make my hole bigger. Its just the offset in the tranny, the motor isnt crooked lol.
01-06-2008, 10:17 PM | #23 | |
Re: 1969 Cougar
Well most of the snow melted so here are some pics Tony.
You probably wanted to see this pic too: I also just figured out how to take a video with sound with this camera so I'll see what kind of footage I can get tomarrow.
01-09-2008, 11:59 AM | #24 | |
Re: 1969 Cougar
Very Nice, you need an Eliminator Hood Scoop, 69 were the same color as the body, 70s were painted black
01-09-2008, 01:43 PM | #25 | |
Re: 1969 Cougar
I have a black Eliminator scoop. Its about a 1/2" too short. They are really low profile.
01-10-2008, 10:43 AM | #26 | |
Re: 1969 Cougar
I thought about running a 4" filter element and a Boss 429 hood scoop.
01-11-2008, 12:26 PM | #27 | |
Re: 1969 Cougar
That would look pretty cool.
Go for it!
01-25-2008, 10:10 AM | #28 | |
Re: 1969 Cougar
Heres a crappy vid of the car.
http://s65.photobucket.com/albums/h2...cember0081.flv I guess the closeup of the mufflers was too much for the little camera. You cant hear it in the clip but it actually cams pretty good.
01-25-2008, 11:30 AM | #29 | ||
Re: 1969 Cougar
That Cougar sounds Great! Is that with the F303? Very nice!!!!!! There is a Boss 302 Eliminator body on ebay in bad shape going for well 4 grand, with no engine, rust all over the place, no trans, or rear, just a crappy shell, Just shows what they are worth no days. Your engine looks damn good as well.
01-25-2008, 01:05 PM | #30 | |
Re: 1969 Cougar
Thanks Tony! I found a couple very small bubbles on the bottom front corner of the pass side door, the pass side rear floor pan has begun to crack, also the bottom corners of the rear glass have some filler smeared in them, and the trunk floor needs new metal. Other than that the body is pretty much solid as a rock. The problems that are there are basically small ones. No patch panels, all 1969 steel.
