Old 01-21-2024, 11:38 AM   #16
Scale-Master
Scale-Master's Avatar
Re: Fiberfab Avenger GT-12
The suspension sits very high if built as it fits together. I lowered the front end almost ¼ of an inch and lowered the rear about 1/8 of an inch. I think I got the camber right on the rear.
Scale-Master is offline   Reply With Quote
Old 01-23-2024, 11:24 AM   #17
Scale-Master
The headlights are supposed to be cemented to the body, but that makes them stand too proud and the outer ones would have to be moved more inward to compensate for the thickness of the headlight covers. I drilled out buckets/openings and tried to make the angled stagger the real cars have as much as possible to capture one aspect of the personality of the car.
Old 01-24-2024, 12:11 PM   #18
Scale-Master
The rear window was missing from my kit so I made a new one from a leftover Monte Carlo stock car back window. (The real car used a '66 Mustang window, but I didn't want to sacrifice one from another kit even if it would fit.)
Here's how I did it:
https://finescale.com/how-to/article...ing-car-window
Old 01-25-2024, 02:53 PM   #19
Scale-Master
I found an equally vintage bottle of never opened Testors enamel paint (1121 Green) that looks pretty close to Fiberfab Green. It had been sitting for decades and was clearly separated (green/white/carrier) so to really shake it up I put it in my sock for my morning run each day and mixed it for 30 miles. These older Testors paints still work very well. I used the same techniques on this as I used back in the '70s when I was building box art for the model companies with it; reduced with lacquer thinner (I don't claim to have "invented" that) and was pleased to see/smell/feel how well it dried in the first 24 hours. Now to let it cure for a while…
Old 01-27-2024, 12:25 PM   #20
Scale-Master
I reworked the mounting pylons on the side mirrors from the same '70 Mustang that provided the steering wheel to fit the Avenger body. The chrome mirror faces were not with them so I made new ones out of Mylar. I used Mylar for the interior VW mirror that came in the kit.
Old 01-29-2024, 12:07 PM   #21
willimo
Sweet, sweet tiny Hondas.
Cool to see how you did the rear glass! I've fixed or modified glass parts like that but never thought to use a technique like that for kitbashing. Excellent
The Following User Says Thank You to willimo For This Useful Post:
Scale-Master (01-30-2024)
Old 02-01-2024, 12:16 PM   #22
Scale-Master
I let the body dry for the better part of two weeks in direct sunlight. The window frames have been foiled and the headlight buckets painted black. The headlights have been installed and the decal I made for the gas door has been applied. It looks like "that tire" had a light snack on one of the clear headlight covers too so I repaired the damage using the same process as I used on the windshield.
The headlight covers fit OK, again especially considering the age of the kit.
Old 02-01-2024, 08:26 PM   #23
Scale-Master
The taillight lenses have been installed and I made a bright silver panel for the interior so you can't see the engine when looking through them.
Old 02-02-2024, 10:34 AM   #24
Scale-Master
The windows have been installed. I decided to sand out the center support strap on the inside of the rear window.
Old 02-02-2024, 07:47 PM   #25
Scale-Master
I cut vinyl for the flat black accents on the hood, quarter windows and side scoops.
I machined an aluminum latch handle and made a license plate and decal for it.
Old 02-03-2024, 11:03 AM   #26
Scale-Master
The wipers, mirrors and door handles are installed. (The door handles came in the kit.)
The Fiberfab badges that go behind the door windows still need to be painted and attached. There is supposed to be one for the hood, but it's a short shot in my kit and I like the cleaner look without it.
Old 02-07-2024, 09:07 AM   #27
Deathtrap
Vintage project. Cool.
I had to look this car up. Never heard of it, although I did recognize a VW engine in the back. And apparently they did use such an engine. I believe there is an aftermarket engine available (3D print) if you want to go that far.
Deathtrap is offline   Reply With Quote
Old 02-07-2024, 01:15 PM   #28
Scale-Master
The Tamiya Beetle engine is very nice. And since I'm a CAD designer I could make my own, but cannibalizing the Tamiya kit would be the easiest option.
The GT-15 version of the car used Corvair running gear.
