Old 12-14-2020, 11:27 AM   #256
Scale-Master
Scale-Master's Avatar
Re: Lola T-70 Mk III
I started working on the oil coolers, but decided to machine the sandwich block and a couple fittings first.
Scale-Master is offline   Reply With Quote
Old 12-16-2020, 06:53 PM   #257
Scale-Master
The kit oil coolers were reworked and had some details added including some machined aluminum items and custom decals. They will be mostly hidden behind the radiator when done.
Old 12-17-2020, 10:53 AM   #258
Scale-Master
The markings have been added to the timing tab and the bolts for the harmonic balancer and lower pulley have added as well.
Old 12-28-2020, 05:06 PM   #259
Scale-Master
I made the first sections of the exhaust pipes, brass, styrene rod and pliable tubing.
Old 01-07-2021, 04:08 AM   #260
DasWiesel
DasWiesel's Avatar
That level of detail is incredible!
Canīt wait to see this one finished.
Julian
DasWiesel is offline   Reply With Quote
Old 01-07-2021, 06:07 AM   #261
LeeABC
LeeABC's Avatar
Really enjoying watching this model come together. I think your approach is the best option for a kit like this; getting satisfaction from doing the best possible job on all the small parts. Eventually, slowly, you'll have a masterpiece!
LeeABC is offline   Reply With Quote
Old 01-08-2021, 11:56 AM   #262
Scale-Master
Thanks guys!
I spent some CAD time this week designing the brake master cylinder.
The clutch master cylinder.
The clutch slave cylinder.
And the J-56 Corvette adjustable proportioning valve & bracket.
Full assembly.
Old 01-08-2021, 07:25 PM   #263
DasWiesel
DasWiesel's Avatar
May I ask, where you get all the measurements from for drawing this?
Do you always have 1:1 parts at hand? Drawings from the manufacturers? Or do you simply guess them?
Julian
Old 01-08-2021, 07:31 PM   #264
Scale-Master
Usually, and in this case I have the 1:1 real parts. I understand the brake adjuster is worth a couple thousand dollars. (It was loaned to me for this project.)
But the dimensions for a lot of parts are listed in catalogs and online at the sellers sites.
The Following User Says Thank You to Scale-Master For This Useful Post:
DasWiesel (01-24-2021)
Old 01-12-2021, 06:31 PM   #265
Scale-Master
For some reason the proportioning valve would not print/grow with the rest of the layout. I tried to print it separately but the printer stopped reading all files, so I made one from scratch the old fashioned way while I try to figure out what the problem is.
Old 01-13-2021, 12:42 PM   #266
Scale-Master
These are the masters I pulled a mold off for the brake and clutch parts. I broke the little bracket extricating it from the RTV, no problem; it will be more resilient as a cast part.
Old 01-14-2021, 11:26 AM   #267
Scale-Master
I got the printer working again and made the original proportioning valve I did in 3D. (I guess it's like losing a part in the carpet; make a new one and you find the original…)
Old 01-16-2021, 09:53 PM   #268
Scale-Master
The cap for the clutch master was made with the other parts, it grew well and even cast nicely, but it didn't look right. So I milled a new one.
Old 01-22-2021, 02:49 PM   #269
Scale-Master
Finished clutch slave cylinder, installed.
Old 02-03-2021, 03:30 PM   #270
Scale-Master
The master cylinder assembly with J56 proportioning valve & bracket and cap w/gasket. Working cap clamps too… (overkill?). The bleeders and front line fitting will be added later.
