| Latest | 0 Rplys |
#241 | |
![]() Join Date: Mar 2008
Re: How many miles do you have your Isuzu?
2001
v6 90,508 Just got it last week. But before we got it....replaced water pump and fuel sending unit.(Gas hand wasn't working) So far so good. Tony |
#242 | |
Hey all, new to the forum and am impressed! Here's my milage stuff:
Year: 2001 (Honda Passport) Engine: 3.2 Mileage: 75000 problems: Have had 2 actual problems - bad Battery and coolant leak coming from that o-ring on the front (on the crossover manifold). With the leak, I went ahead and not only replaced the o-ring, but wound up taking off the entire intake plenum and fuel rails to replace all the coolant lines underneath along with the radiator hoses. The intake gaskets, t-stat and fuel injector o-rings got replaced too - kinda went a bit overboard that time! some other maint stuff: regular oil changes 3000-5000 miles, recently went to full synthetic. xmission fluid changed at 68000. rear diff fluid changed 70000. coolant changed with above (about 72000). changed timing belt and plugs at about 63000. Think I'm about up to factory specs minus front bearing repack |
#243 | |
1997 Honda Passport LX 4x4 5spd
132,000 miles so far so good |
#244 | |
New to the forum, everyone has been very helpful so far.
97 Rodeo LS 3.2 L 4X 153,147 miles 2" Calmini susp. lift, 31 X 10's, and a Carr light bar with four 100 W lamps on top. Bright. No major repairs. Within the last 6 months new alt, battery, cv axles, t-belt, water pump, wheel bearings, leaf springs, and a very expensive side mirror. My 93 Amigo XS bit the dust at 145k last summer. I am In the process of selling one of my 97 Rodeos with 157k to a friend. I'm down to my last (and best) Isuzu. The thing has been an absolute tank for what I have put it through. I think these things are great. |
#245 | |
![]() Join Date: May 2008
98
3.2 Auto 125,000 Just purchased did the 120k dealer service. How far will it go... hopefull 4 years more through school!! |
#246 | |
1999 Rodeo LS 3.2 L 2X - 135,000+ Miles.
Was purchased used in 2000, after my still very new 1999 was stolen. This is my 4th Rodeo. ![]()
- azrx -
- 1999 Rodeo LS : 135,000+ Miles - - http://legacy-game.net - - http://thewrestlinggame.come - |
#247 | |
hey is there anyone here
#248 | |
Year: 2000
Engine: 3.2 Liter Mileage: 160,000 Any major problems: Transmission
2000 Isuzu Rodeo -160,000 miles 2006 Chevrolet Silverado HD2500 Duramax |
#249 | |
My rodeo has a check engine light on, a reduced power light, and tire pressure monitoring (TPM) light on.
The codes displayed are P1125, P1295, P1515, P1516, P0507, P0101. The reduced power light slows it down to a crawl. |
#250 | |
1994 Honda Passport SE
3.2L 193,000 miles Problems (in past year I've had it): rear diff. leak; CV joint; valve-lifter noise; broken ball joint; steering idler arm; valve-cover leak; numerous wiring problems; rust problems w/mechanicals (ex: door locks); PS pump leak; transmission slip (clogged filter); window tracks (3 of 4 stick); sunroof leak. Basically, typical things considering its age and mileage. |
#251 | |
97 Passport
174K as of 8/08 Ignition switch and alternator everything else was replace at it's maitenance interval
My car is not "raggedy"....it just needs a lot of "minor" work.... |
#252 | |
1994
3.2 200000 waterpump,timingbelt,powersteering hoses,all hoses,belts,front end,battery,electric windows,ac,wheel lugs,rocker arm cover gaskets,if its not one thing its the other. |
#253 | |
2000 LS
3.2 V6 120K Replaced head gasket, Tires, fuel sending unit, Nothing else major!!!!! ![]() |
#254 | |
Just Bought a 95 Passport w/ 206k on it
#255 | |
![]() Join Date: Jul 2007
1997 Rodeo LS
180K 3.2L auto 4x2 Annual update (at least I think it's been a year!): Needed to change a starter and replace an O2 sensor fuse, but just regular maintenance otherwise. It has been a really cheap vehicle to keep on the road lately.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K '96 Jetta 249K '97 TJ 156K '02 VW Cabrio 70K '03 E46 107K |
