| Latest | 0 Rplys |
07-21-2003, 10:16 PM | #226 | |
1995 chevy truck, Z-71 keyless entry programming?
1995 Chevy 7-71 remote keyless entry programming? how's it done? is my transmitter the right one? its GM p/n 15955701. thankyou SOOOOOOOOOO much!!!!!!!!
07-25-2003, 04:01 PM | #227 | |
keyless remote programming 02 Silverado
Got a 2002 Silverado - where can I find instructions to program it's remote? Hopefully it won't require a GM scan tool.
Thanks!
========= Boss |
07-27-2003, 04:35 PM | #228 | |
Added keyless to 2001 GMC Sierra
I just installed a GM receiver with fobs in my 2001 GMC Sierra. (my truck did not have the keyless option installed).
On the fuse panel it says.. "When equipped with power locks without keyless entry, install 30A fuse. When equipped with power locks and keyless entry, install relay" I assume I would get this relay at the dealer and place it in place of the 30A fuse that is there now?? also... is this why the unit is not working?? I was told the unit should work without programming...what is the programming sequence in case I need to go that route? Thank you for any help !! >>Skip |
07-28-2003, 02:23 PM | #229 | |
Which Reciever do I have?
2001 Chevy Suburban, I bought it used without any FOB's. I would like to buy some FOB's off ebay and save me some $$$.
Parts Dealer at local dealership says that there are two systems that could be on my suburban, he says match the receiver part numbers to the transmitter. Here are the part numbers: Receiver Transmitter 15732806 15732803 (..or..) 15042969 15042968 Question: Where is the receiver located so that I can get the part number? Parts dealer guessed somewhere behind the center dash, up high. Is there any other way to know which transmitter I need, I've seen both transmitters on ebay for about $10/each. Dealer wants $85. I've searched the forums and haven't found anything on it. TIA, Rhino. |
07-29-2003, 01:17 AM | #230 | |
1997 Lumina sedan keyless rermote programming
Anybody have the programming instructions for a 1997 Lumina sedan??
Would greatly appreciate any help. Thanx Jim ZZZZZZZZZ |
07-29-2003, 10:56 AM | #231 | |
Some help for Rhino
Rhino:
You were asking about locating your receiver to get the part number.... I can tell you where it is on a 2001 GMC Sierra since I installed one just a few days ago. This sounds much harder than it is, but here goes 1. Pull off dash trim (will pop off with even, easy pressure). 2. Lower steering wheel, put on parking brakes and pull down shift lever go give you better access. 3. remove trim. 4. unscrew 4 instrument panel screws and pull forward (one long cable to panel will allow you to move it to the side without removing. 5. keyless module is located in the upper right side, on top of dash opening (the size of a deck of cards, plugged in with 3 wires, 2 orange and one black). It is secured with 2 plastic legs in front which you can push back thru the holes and angle up to unsecure the back solid leg. Good luck. >>Skip |
07-30-2003, 10:05 AM | #232 | |
Thanks to Skip
Skip,
Thanks for the instructions, it took me less than 30 minutes to find the part number and put it back together. You Da Man, Skip! Sincerely, Rhino. |
07-30-2003, 01:54 PM | #233 | |
Glad it worked, Rhino!
Rhino:
No problem, glad I could help! >>Skip |
08-02-2003, 02:23 PM | #234 | |
97 Suburban Keyless question?
I lost my keyless entry remote. My friend works at a dealer and has a few extra remotes, and said if I can get them to work they're mine. I did a search and found 1 way to do it, but it didn't work.
I read that I had to jump the #4 and #8 pin at the data link connector and the doors would lock and un-lock. I tried this with the key on and off, but nothing happens? I used the plug under the dash where you hook the scanalyzer, is that right? Can somebody tell me how to program a remote? I do have remotes that exactly match the one I had with my Suburban. Thanks for the help! |
08-04-2003, 07:28 PM | #235 | |
HELP !!
I was finally able to get a remote for my 95 olds silhouette van but the dealer wants $80+ to program it. Can any one please help. Thanks in advance
08-25-2003, 06:00 PM | #236 | |
1995 Pontiac Trans Sport 3800
I apologize for posting here in the Chevy area, but this seems like the best place to get the question answered. Does anyone know how to program the keyless entry for a '95 Pontiac Trans Sport. Bought from a friend and it was sitting without a battery. Any help would be greatly appreciated!
08-29-2003, 03:21 PM | #237 | |
1997 Grand Am
Anyone ever figure out the 97 Grand Am Keyless entry program?
09-04-2003, 01:18 PM | #238 | |
1994 pontiac transport keyless entry programing
The dealer wants far too much. Can anyone help with instruction on how to program the keyless entry? Thanks!
09-06-2003, 03:17 PM | #239 | ||
Re: Re: keyless remote 2001 olds silhouette
09-09-2003, 03:27 AM | #240 | |
97 GMC YUKON Keyless Entry Programming
Sorry to post GMC questions in the Chevy forum but this seems to be the place to get answers about keyless entry.
Will someone please provide me with the procedure for programming the keyless entry remotes for a 97 Yukon? Thanks very much. |
