| Latest | 0 Rplys |
WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
10-15-2020, 11:44 AM | #211 | |
Re: Lola T-70 Mk III
The front starter bracket, more brass, formed from one piece. I used solder to make the fillet as it is a stamped steel piece on the real engine.
10-15-2020, 02:03 PM | #212 | |
man i hate to keep saying the same things after every time you post, but this is awesome!!
10-16-2020, 05:06 AM | #213 | |
I want to see you build this in 1/1. Would be better than the original.
10-19-2020, 05:18 PM | #214 | |
Thanks Guys!!!
I machined the mounting hardware from aluminum. Also note the Philips heads in the starter case. I'll make the electrical connectors later. For now the starter is done. |
10-21-2020, 05:19 PM | #215 | |
The distributor will be an OEM GM item too; a recurved HEI unit from an L82, (like on my real car).
I designed the cap and coil in SolidWorks. The electrical connection plugs will be grown on it too, but I won't be using the ring that locks the plug boots in place, it's a pain in real life. |
10-24-2020, 10:06 PM | #216 | |
I machined the breather can from aluminum.
10-29-2020, 03:43 PM | #217 | |
Knowing the inside would probably not grow as clean as needed to fit to the aluminum distributor base I grew a jig with it to hold the cap so it could be machined to fit. Worked like a charm too.
The distributor base was machined from aluminum. The cap is a cast resin copy. |
10-30-2020, 11:24 AM | #218 | |
Oil filter machined from resin stock. It will be a Delco PF1218. (More parts off my real car…)
11-02-2020, 05:30 PM | #219 | |
Finished oil filter. I milled out the mounting location of the block so the filter sits in to it instead of flush on it. Made a decal for the label.* I date my filters when I install them. Taking a guess on this one…
11-03-2020, 12:51 PM | #220 | |
Distributor base and vacuum advance canister machined from aluminum.
11-04-2020, 01:35 PM | #221 | |
Shiny new distributor cap.
11-07-2020, 03:53 PM | #222 | |
Hold down clamps, nickle wire.
11-07-2020, 05:43 PM | #223 | |
Assembled scratch-built HEI distributor. I'll add the tach and power wires later, the plugs are already on it.
11-11-2020, 11:02 AM | #224 | |
The distributor boots for the ignition wires; made from scratch.
(Return of the big ruler…) |
11-11-2020, 11:41 AM | #225 | |
What material did you use to make the boots?
