Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-12-2007, 03:04 AM   #211
ibew595
ibew595's Avatar
Send a message via AIM to ibew595
Re: How many miles do you have your Isuzu?
168k purchased new
1994 LS 4wd V6
Still haven't done a brake job on it yet, about 3mm worth of pad on the front with no grooving and it looks like all 4 of the rotors are not worn very much at all.
The "tick" but diesel oil sure helps alot. I've tried seafoam,different treatments all which didn't work. Only fully synthetic oil or diesel oil kept it quiet.
timing belt, 2 window regulators,starter and now the alternator have been worked on.
A 50' pine tree did fall on it and cause 7k in damage.
email"A.F."in subject line only
Mt. Hamilton 9/03
Kevin Goto
2000 740 i
Impala Brown
Annalisa
ibew595 is offline   Reply With Quote
Old 08-23-2007, 02:25 AM   #212
Teile
Send a message via AIM to Teile
1993 Isuzu Rodeo 4wd
151,545 miles
Teile is offline   Reply With Quote
Old 08-25-2007, 05:22 PM   #213
GEN XER
Year: 1993
Engine: 3.2L V6
Mileage: 230,000
Any major problems: Replaced 32 lifters in 1995. Nothing else major.
GEN XER is offline   Reply With Quote
Old 09-04-2007, 12:06 AM   #214
H2odrx
Post Re: How many miles do you have your Isuzu?
Year:1995.5
Engine:3.2l
Mileage:188k
Any major problems: low oil pressure, knocks bad (top), runs rough @ 2k rpms.
H2odrx is offline   Reply With Quote
Old 09-07-2007, 04:28 PM   #215
jasons93rodeo
1993
2.6 5 spd
150856
remanned head, timing belt, tensioner,tires,radiater,thermostat,all new vacumn lines,new plugs,wires,g-05 antifreeze.
but runs like a scalded dog
jasons93rodeo is offline   Reply With Quote
Old 10-16-2007, 10:43 AM   #216
onerobertone
Year:2001
Engine:V6
Mileage:112,000
Any major problems:Just the flashing check engine light. I hear tail it's the spark plugs.
onerobertone is offline   Reply With Quote
Old 10-18-2007, 06:41 PM   #217
andrew_j
andrew_j's Avatar
1996 Passport 4x4 EX
V6
160,000
problems-tick, cv's, warped rotors, bad leaf spring bushing, two regulators down...runs great never lets me down
1996 Honda Passport EX 4x4
On it's way to 161k FOR SALE!!!!
2000 Acuera Integra LS 5 speed
andrew_j is offline   Reply With Quote
Old 10-20-2007, 12:17 AM   #218
HI JOHN
Talking Re: How many miles do you have your Isuzu?
97 3.2 with 135K and running like a top.
HI JOHN is offline   Reply With Quote
The Following User Says Thank You to HI JOHN For This Useful Post:
cherry97rodeo2WD (08-02-2021)
Old 10-23-2007, 01:33 PM   #219
kdavid
Send a message via Yahoo to kdavid
Hi All: i'm kevin & i'm an ex-dodge fan.
1994
3.2/auto (my first in a truck)
209716 as of right now.
only lately has it developed some lifter chatter (some help here please?--don't know much about these engines.)
& one of the trans. cooler lines started to leak.
i'm the 2'nd owner--bought it about 6 months ago. why?
well--because i've wanted one since the rodeo first hit the market
here in sunny arizona. (& the dogs love it )
interesting forum here.
kdavid is offline   Reply With Quote
Old 10-23-2007, 06:58 PM   #220
GEN XER
Rodeo's have a normal tick. Get some synthetic 10w30 this will quite things down. You can also use some Lucas oil treatment. If you are really outside the box get some quantum blue oil from BND Automotives.
Old 10-24-2007, 11:45 AM   #221
kdavid
Thank you GenXer--i forgot Lucas---used to use their products a lot when i was driving towtrucks. Great stuff!!!
The DogHouse A.K.A. 'Eugene III'
Old 10-27-2007, 07:25 PM   #222
CJOHNSON57
2000
3.2 v6
103k Oct 2007
Oil pump went out and caused rod bearings to go out. Looking for a cheap engine to swap out.
CJOHNSON57 is offline   Reply With Quote
Old 11-02-2007, 12:54 PM   #223
G35Coupe_Girl03
G35Coupe_Girl03's Avatar
Smile Re: How many miles do you have your Isuzu?
Year: 1998
Engine: V6
Mileage: 180,000
problems: After market- 3 inch lift made my brake lines blow two times, new exhaust, needs new o2 sensor and gas cap cause its making my check engine light appear, other than that its running like a champ considering i dont drive it all that much any more bc i have a G35 so the rodeo is really just a winter car.
G35Coupe_Girl03 is offline   Reply With Quote
Old 11-13-2007, 11:21 PM   #224
nozelle
99 Rodeo, 3.2 V6 94K miles
Major problem: Troubling shooting and enventually replacing the engine crank shaft position sensor.
Usual Rodeo problem: fuel gas sending unit-replaced
No major engine problems-valve cover gasket leaks a bit and now the AC evaporator fins are plugged but no biggie there.
nozelle is offline   Reply With Quote
Old 11-16-2007, 01:03 AM   #225
hazegrey
Thought it time to update my mileage
Miles:121k
The truck has been running like a champ with just two minor problems, one of which I caused.
Power steering pump gave out at 120k and I had to replace the drivers side mirror after clipping a pole
knock on wood it will keep going till well past 200k
97 RODEO LS 2WD 121K mi
08 Saturn Outlook FWD XE
hazegrey is offline   Reply With Quote
