Go Back   Automotive Forums .com Car Chat > Ford > Focus | C Max
Old 09-01-2013, 06:54 PM   #1
gene4545
2009 focus High RPM and Transmission not shifting proper
I have a 2009 ford focus The rpms are hight and the transmission is not shifting when it should give me a idea where to look Thanks
gene4545 is offline   Reply With Quote
Old 09-01-2013, 07:06 PM   #2
The Ruth
The Ruth's Avatar
Re: 2009 focus High RPM and Transmission not shifting proper
Are the rpms high in every gear? Does the transmission shutter or clunk when it does shift?
'14 Ford Escape
'13 Ford Focus
'88 Ford Mustang
www.HelpUFindStuff.com
The Ruth is offline   Reply With Quote
Old 09-01-2013, 07:23 PM   #3
gene4545
yes high in every gear trumps when shifting Just a thought could it be a fuse
Old 09-01-2013, 07:34 PM   #4
The Ruth
The Ruth's Avatar
It wouldn't be a fuse. Best case scenario is that it's the speed sensor, or the computer needs re-programmed.. but more than likely the trans is bad if you have trouble consistently in every gear, and it physically makes a sound when it shifts.
With limited information it's hard to say exactly what it could be. Fords around that year were infamous for consistent trans issues. A lot had a defect in the case, and had issues with the driver's side short shaft.
'14 Ford Escape
'13 Ford Focus
'88 Ford Mustang
Old 09-01-2013, 09:27 PM   #5
gene4545
thanks for the info I forgot to tell you the check engine light came on when the problem started
Old 09-02-2013, 09:10 AM   #6
The Ruth
The Ruth's Avatar
Have the check engine light code checked.. that will usually point you in the right direction.
'14 Ford Escape
'13 Ford Focus
'88 Ford Mustang
Old 09-02-2013, 09:43 AM   #7
kevinande
kevinande's Avatar
How many miles are on the car? Did you check the transmission fluid for quantity and take a whiff? Does it smell burnt? Based on the limited info available, I'm leaning towards low fluid or transmission failure.
1998 Escort ZX2
2004 Mazda RX8
2007 Honda Accord
2011 Ford F150
kevinande is offline   Reply With Quote
Old 09-02-2013, 06:05 PM   #8
gene4545
Its my daughters car I was going on info she was giving me I drove it today There is 103K miles the transmission is shifting ok But it is not going into or out of the overdrive I got it to function a couple of times then it would do it no more. I also did a check engine test and the co sensor is bad I have not installed a new one yet I guess what we are looking for is why it is not shifting into and out of overdrive
