Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 07-09-2011, 11:52 AM   #1
qwertydog
Smile How to disable tailgate light switch
After having a flat battery in my '02 Windstar caused by the tailgate being open all day, I decided to do something about it.
The solution is an easy fix that anyone can do.
Here's the procedure : Open tailgate, remove pull down handle, remove 2 X head screws 1 each side of plastic panel, pull panel off tailgate, unplug wires from both latches, remove 2 or 3 inches of outer covering from wires near the plugs, join the 2 wires together at each plug, install the plugs back on the latches, put the plastic panel back on, put the pull down handle back on and you are done.
Now when I am at an outside function I can have the tailgate open all day.
Note : This does not affect any other door lights or the remote locks.
Enjoy !
qwertydog is offline   Reply With Quote
The Following User Says Thank You to qwertydog For This Useful Post:
tempfixit (07-09-2011)
Old 07-09-2011, 12:34 PM   #2
tempfixit
Re: How to disable tailgate light switch
Enjoy !
Thanks for posting as it will help someone in the future.
tempfixit is offline   Reply With Quote
Old 07-09-2011, 01:03 PM   #3
kevink1955
Having the tailgate open should not kill the battery, the lights should go out within 10 to 20 minutes. Something is wrong with the body control module or the accessory relay. What you did will cover up the current problem but keep an eye on other functions like brake lights, turn signals and backup lights as they are controled by the same module.
kevink1955 is offline   Reply With Quote
Old 07-09-2011, 10:03 PM   #4
olopezm
olopezm's Avatar
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
It's a good suggestion but I wouldn't plug the connectors in again, current will always follow the path with the least resistance (that's the union between both wires). If the problem were the lights being on all the time wouldn't have just been easier to move the dimmer switch all the way down?.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
olopezm is offline   Reply With Quote
'01 Sport rear tailgate light switch qwertydog Windstar 5 07-05-2011 07:49 AM
2000 cougar brake switch. HELP! MKO1988 Cougar 0 06-09-2010 10:38 PM
TIP: Fix those doorjam switches // no dome light... Intuit Escort 3 11-21-2009 11:27 PM
Brake Light Switch uspres2020 Escort 5 09-28-2009 01:11 AM
2003 Venture Headlight Switch Wiring Diagram kapinossa Venture 0 09-20-2009 12:25 AM
