Go Back   Automotive Forums .com Car Chat > Chevrolet > Express | G Van
Old 11-11-2010, 09:56 AM   #1
CT-Ken
2002 Express LS 1500 Courtesy Lights Inop for RF door only
I have a loaded up(power: windows, locks, mirrors, etc) 2002 Express LS 1500 8-pass window van with an interior courtesy light problem. The interior courtesy lights work properly when I open the driver's (LF), rear cargo (RR), and side barn door style doors. When I open the front pass (RF) door, all the interior courtesy lights remain dark. I suspect that the "door jamb switch" is bad, so I've started the research to replace that part. When I look it up in my GM 02 Express Van factory service manual, I see a picture of it attached to the door latch mechanism (inside the door shell). It does not appear to be the classic GM plunger switch style I have seen for many, many years. When I look around the door opening on the truck, I do not see any kind of plunger style switch on the front doors, so it appears that it must be some kind of internal switch, as suggested by the picture. Next, I went to a GM parts supplier where I buy a lot of my genuine GM parts. They always look up parts by vin number. For my vin number they tell me the part I need is "22601896 - Door jamb switch." But, when I view a pic of this part, I see it is an old style plunger style switch. I do not think that is correct for my truck. (I have asked my parts supplier to look it up again)
Edit - my GM supplier came back with a different "correct" part number. It is -
16629726 Passenger side front side door lock assembly; less actuator.
When I look at a pic of that part, I do not see any kind of switch, so I suspect that part is incorrect as well.
However, for those of you that have knowledge and experience with this kind of problem, I have a few questions:
1) Am I on target with replacing the RF door jamb switch?
2) Is there a different door jamb switch I need, other than the ones noted above, that should be used in place of 22601896, or 16629726? Would you have the part number and a brief description of it, how it attaches, etc?
Thanks in advance for any help from the forum !!
CT-Ken is offline   Reply With Quote
'05 Dodge Ram 1500 - Tail Lights Not Working DodgeRam1500 Ram Pickup | Ram SRT10 10 12-27-2014 01:58 AM
2002 Express dome light issue jtram2 Express | G Van 2 07-23-2010 08:57 AM
03 tahoe inside door courtesy light lou S. Tahoe 1 11-14-2008 10:25 AM
Courtesy light in door... chuck16 C/K 4 08-13-2004 04:30 AM
